Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 21, 2008, 02:16 PM   #1
Personal Sales Rating: (4)
Drives: 03 Lancer Es
Breaking in a Piggyback
how long does it normally take for it to break in has anyone had the same problem as me ? where the car is surging and turning off after its warmed up ? if so how long did it take to fix or what did you do to fix it ?
Offline
Old Mar 26, 2009, 02:52 PM   #2
Personal Sales Rating: (5)
mtags24's Avatar
Drives: 40+ MPG Lancer!
What do you mean by breaking in a piggy back?
There shouldn't be any "breaking in period", but there is a learning curve for the ecu. Remember after installing something like this or resetting the ECU (keeping the battery off for 30 min or so) that you must let the car idle for a minimum of 10 minutes and then drive conservatively as it learns. Don't rev high or hit the high way right after install.
Also, if you did the above and are still having problems, odds are you botched the install. Contact RRM
Offline
Old Mar 27, 2009, 10:47 AM   #3
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
Hammer, plyers, screw driver... takes about 30 seconds to "break in".
Most piggy issues are user errors, so I'd say you may have wired it wrong, or your connections aren't good enough.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Apr 21, 2009, 02:32 AM   #4
Personal Sales Rating: (0)
mxviper73's Avatar
Drives: 06 Lancer OZ Rally
Send a message via Yahoo to mxviper73
Do you think he has the wrong one installed , cause t looks like the OZ , will not work in the ES. I Think , the difference between manual and auto and V1 &v2 ? which one do you have?
Offline
Old Apr 21, 2009, 05:54 AM   #5
blaze_125's Avatar
Drives: Yellow OZ
Quote:
I got version 1. This version could be wired to both auto and manual trans as long as you spliced the proper wires.
I don't know about other versions. But I know wiring is usually the problem.
__________________
Offline
Tags
breaking, lancer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
