Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 18, 2008, 01:33 AM   #1
Personal Sales Rating: (19)
sykou's Avatar
Drives: 2003 Lancer OZ Rally
Angry EcuFlash...wrx 440s shut off at idle???
So i got some wrx 440s tuned in with ECUflash and it idles fine, the fuel trims are pretty good but the only problem is that when i let off the throttle and press the clutch in while coming to a stop, say in slow moving traffic, my afrs will drop to about 20ish(which is off BTW) and then bounce back to 14ish and then back and forth a few times before coming bak to a steady idle of around 14.3-15 AFR... I have no partial throttle issues or WOT issues... I think it may be something to do with the injector latencies but i dont know which direction i should go with it(add to the latency values or subtract from them)?? hope someone can be of some help... thanks in advance!
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Old Sep 18, 2008, 10:25 PM   #2
sykou's Avatar
nobody?
__________________
Offline
Old Oct 17, 2008, 12:14 AM   #3
Personal Sales Rating: (0)
Complink's Avatar
Drives: 03 Lancer OZ 16g
the ecu will employ fuel cut at no throttle above 1500 rpm. but if its doing this below that then you may have a latency issue. I think you increase the latency value to increase fuel since it will open sooner. someone correct me if im wrong.
Offline
Old Oct 17, 2008, 12:16 AM   #4
Personal Sales Rating: (2)
Magnumpsi's Avatar
Try and increase the latency at 12-14volts by just a bit and see if that helps. My guess is you will benefit from a little bit of extra fuel there.
Mitch
__________________
Mitch Mckee
Tuner
Offline
Old Oct 19, 2008, 01:38 AM   #5
sykou's Avatar
will try that out...Should i just increment it once or should i add a certain percentage??
__________________
Offline
Old Oct 24, 2008, 08:24 AM   #6
TouringBubble's Avatar
Drives: IX MR SE
Send a message via AIM to TouringBubble
Don't increment latencies ... bump up by .02 or so each time. Manually enter the value.
__________________
My Sponsor House Profile | EPM | AMSOIL | GTWorx
"We two souls have shared a cheese sandwich more than twice!"
Offline
Tags
ecuflash, injector, latency, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
