Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 12, 2008, 01:54 AM   #1
Registered User
Personal Sales Rating: (0)
Drives: 02 lancer
OK ecu flash switch from piggy, help
Okay I've been reading for hours on this, and I downloaded it, and I'm going to order the cable tomorrow, I have a t3 turbo 02 lancer 550injectors and piggy....I'm sure this has been around for sometime, so is there some guys on here with similiar turbo setups that have maps I can just copy and then adjust from there? Thanks!
Offline
Old Aug 12, 2008, 01:43 PM   #2
Personal Sales Rating: (3)
I have 560 cc injectors, t 25, 11 psi, running pretty decent. I just tuned this weekend and I am finally getting no readable knock in my logs, 11.3- 10.9 afr's ( on the rich side, but is ready for fine tuning once I figure out my wideband issue). I would suggest just tuning with a wideband, after I got my car to idle it was pretty easy to tune. I think I have my injector scaling at 440. You will need to adjust your Injector battery latency to get the car to idle. I can check what I set mine to later. I think I dropped the ms some.
Offline
Old Aug 12, 2008, 01:45 PM   #3
Oh, also adjust the latency for 14.06 volts.
Offline
Old Aug 12, 2008, 02:48 PM   #4
Registered User
Drives: 02 lancer
Lol, ok thank you, I'm going to have to get a bit more handy w/ the software first, but can you tell me why we HAVE to use the tantrix or w/e it is cable, why wont any obd2 to usb cable work? thanks a lot
Offline
Old Aug 14, 2008, 12:54 PM   #5
I honestly don't know the cable appears to just break out the connections from the usb to an obdII pin, but I don't want to rip my cable apart to find out. But for the cost of evoscan and the cable you can't go wrong.
Offline
Old Aug 15, 2008, 12:38 PM   #6
Registered User
Drives: 02 lancer
ok im going to check it out and get back to you, thanks
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
