Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 11, 2008, 08:38 AM   #1
Personal Sales Rating: (0)
EcuFlash tunning help
my setup is:
turbo custom
injectors 440 cc
pump walbro 255
ecuflash
my problem is the following one
load
0-100 it is ok
but 100-180 the AFR change of
2psi - 15 AFR
3psi - 16 AFR
4 psi - 17 AFR
before ecuflash i running with apexi neo and be fine at 10psi
now i change the maps with ecuflash but i cant run fine
these is my maps, please tell me that I can move to run fine
Thanks you
sorry for my English, i hope understand me
these are my maps
Offline
Old Aug 28, 2008, 02:02 AM   #2
Personal Sales Rating: (19)
sykou's Avatar
Drives: 2003 Lancer OZ Rally
hmmm from looking at your map you might wanna change the ranges you have your loads defined as... ex: you got ...60 70 80 then 153?! that is a big jump. You should try something like this...10 20 40 60 70 80 90 100 120 130. Are you seeing anything near 180% load? post a video of one of your logs showing the load, rpm, wideband AFR, etc.
Also when you add load values in the load % area you also have to do the same int he ingintion tables. Cuz if your seeing 120% load your ECU will only be able to determine how much fuel to send btu it wont know what to do with the timing.
Do you have a fmu? i think your fpr is not allowing enough fuel out. even though you got bigger injectors and a upgraded fuel pump if you got a stock fpr it will still limit the fuel pressure.
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Old Aug 28, 2008, 08:31 AM   #3
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
How do you know how much load your engine is under? Are you datalogging with EvoScan or any similar software that reads your engine load from the ECU? Most turbo Lancer setups don't see more than 120-130% load from the ECU and that's at like 10psi. You might want to lower your load values and also adjust your ignition values like sykou stated above.
Offline
Old Aug 29, 2008, 03:10 PM   #4
ok, finaly i can run at 10 psi. but for do that i was need to move to limits the maps of fuel and timing, also move to 0 the load open loop. and resize injectors the car run fine and very fast
Offline
Old Oct 9, 2008, 01:32 AM   #5
03LancerUTI's Avatar
Drives: 2003 mitsubishi lancer oz rally
ok so ive heard ecu flashing or piggyback, i understand that piggy back is limited and more so a plug and play while the flash you can change more. im starting to mod my car and i want to get into flashing but i want to understand it more so i know what im getting into.
Offline
Tags
ecuflash, engine, lancer, load, oz, tuning, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
