Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 15, 2008, 09:14 PM   #1
Personal Sales Rating: (1)
bigern2006's Avatar
Drives: 2003 lancer oz rally
hard time tuning...
Im trying to edit my ECU data and it i difficult to understand when i cant read the values... this is a pic of what it looks like maybe there is something im forgeting or idk im new to this maybe someone can help...
__________________
- Cold Air Intake
- N1 2.5" Cat Back
- Short Shifter
- JDM Ralliart Grille
- Eibach Ground Control Coilovers
- OBX-R Header
- Clutch Masters Light weight flywheel
- Fidanza adjustable Cam Gear
- AEM Wideband
- RRM Solid Motor Mounts
- RRM CEL eliminator
- Gunmetal stock OZ wheels
- Tinted taillights
- Shaved oz rally from trunk kept the Diamonds
- Energy suspension sway bar endlink kit
- EVO IX Wing
Offline
Old Jul 15, 2008, 09:16 PM   #2
bigern2006's Avatar
I look on the tutorials and the numbers look normal... but mine do not idk... lol... just my luck...
__________________
- Cold Air Intake
- N1 2.5" Cat Back
- Short Shifter
- OBX-R Header
- AEM Wideband
- Tinted taillights
- EVO IX Wing
Offline
Old Jul 15, 2008, 09:19 PM   #3
Personal Sales Rating: (12)
wickdaddy's Avatar
Drives: Tarmac Black Evo VIII
Send a message via AIM to wickdaddy
Now I haven't looked at ECUflash in a little while, but those values on the header columns and rows don't look right at all.. did you get the correct rom for your car and make sure it is in the right folder and such?
__________________
三菱
tb8 gsr
Stock Turbo @ 24 psi // GSC 264 cams // APR Head Studs
Walbro 255 // 680cc injectors
RSR DP // JIC full Ti Exhaust // ACT Ceramic Single Disk // MR BOV
Defi Amber Boost, Water, EGT + Monitor // PLX Wideband
301awhp: Dynoflash tuned @ Buschur
FS: BNIB FIDANZA FLYWHEELS
green cloth
Offline
Old Jul 19, 2008, 11:40 PM   #4
Personal Sales Rating: (0)
TouringBubble's Avatar
Drives: IX MR SE
Send a message via AIM to TouringBubble
You might need to change the endian value for the RPM and Load scaling ...
Right -click any map/table in the left column
Select edit map
Click the Scalings button
Select RPM or Load
Click Edit
Change the endian value to the opposite of what it is ... little to big, big to little
Click OK, exit, apply, OK
Check the map and see if it's correct
__________________
My Sponsor House Profile | EPM | AMSOIL | GTWorx
"We two souls have shared a cheese sandwich more than twice!"
Offline
Old Jul 20, 2008, 11:32 AM   #5
bigern2006's Avatar
OMG it worked Thanx so much now i can tune.. yeay.. thank you again...
__________________
- Cold Air Intake
- N1 2.5" Cat Back
- Short Shifter
- OBX-R Header
- AEM Wideband
- Tinted taillights
- EVO IX Wing
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
