Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 14, 2008, 07:43 PM   #1
Personal Sales Rating: (1)
bigern2006's Avatar
Drives: 2003 lancer oz rally
Base Map
Hey guys i just got my tactrix cable and downloaded ecuflash and it is freaking sweeet... lol.. but anyways i was having problems with my ECU from the dealer flashing the ECU for some recall... and was wondering if someone had Base maps of there 2003 Lancer OZ... so maybe i could see if that makes a difference in driveability, then tune from that so i dont have to go to extremes trying to get my car running right... not sure if this is possible or not but was wanting to give it a try...
__________________
- Cold Air Intake
- N1 2.5" Cat Back
- Short Shifter
- JDM Ralliart Grille
- Eibach Ground Control Coilovers
- OBX-R Header
- Clutch Masters Light weight flywheel
- Fidanza adjustable Cam Gear
- AEM Wideband
- RRM Solid Motor Mounts
- RRM CEL eliminator
- Gunmetal stock OZ wheels
- Tinted taillights
- Shaved oz rally from trunk kept the Diamonds
- Energy suspension sway bar endlink kit
- EVO IX Wing
Offline
Old Jul 14, 2008, 07:53 PM   #2
Personal Sales Rating: (4)
Protostar1's Avatar
Drives: 2006 Mitsubishi Evolution SE, 1970 Porsche 911T
Look on AktiveMatrix.com, last time I looked, they had the stock Evo maps, they might have the base lancer maps. Not sure, but its worth a look.
__________________
350 awhp 321 awtq @ 24.5psi on 93oct (SAE Correction)- AMS Tuned
- ETS 4" IC - ETS LICP - ETS UICP - ETS Intake - Perrin Filter -
- BR 3" TBE w/ test pipe - Buschur o2 Housing -
- AMS MBC -
- ETS Battery - Walbro 255 - S-M DC3 - ETS Radiator Hose -
- EnduraTech Coilovers (7k/9k)-
- AMS Brake Ducts - Hawk HT10/ PF Metallic Z - Technafit SS lines -
- Enkei RPF1 - Nitto NT05 -
- APR Splitter -
- Motul RBF600 - AMSoil -
- Stri Gauge -
Offline
Old Jul 14, 2008, 09:48 PM   #3
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
You'd be much better off starting from scratch. The term "base map" is relative in that it would have to have been made by someone with the same engine mods as you. You might end up having to perform more tuning if you use someone else's map as base.
Offline
Old Jul 15, 2008, 10:23 AM   #4
bigern2006's Avatar
well a factory base map one that has not been reflashed fora recall... so hats why i was wondering if i could get a base map some how.. plus my car seems to operate better with the factory base map... just wondering if someone has a map that hasnt been reflashed from factory map... thanx..
__________________
- Cold Air Intake
- N1 2.5" Cat Back
- Short Shifter
- OBX-R Header
- AEM Wideband
- Tinted taillights
- EVO IX Wing
Offline
Old Jul 15, 2008, 02:00 PM   #5
Quote:
You didn't make a copy of your original ROM? What is the ROM ID? Without this nobody will know what you need.
Offline
Old Jul 15, 2008, 06:29 PM   #6
bigern2006's Avatar
81900006 is the definition file... im not sure what the rom I know the case number of the PCM it is MR988327 i belive off the top of my head... not excatly sure what rom ID is im kinda new at this just trying to learn...
__________________
- Cold Air Intake
- N1 2.5" Cat Back
- Short Shifter
- OBX-R Header
- AEM Wideband
- Tinted taillights
- EVO IX Wing
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
