Apex'i SAFC NEO
Looking in the speedcorps site they are selling a engein managemente from Apexi,
APEXI SAFC NEO
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Features include:
- Completely new case design
- Compact design
- Incorporates both AFC and VAFC functions in one unit
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
will it work have some one bought it yet? anything
__________________
[X] - Rally Series Rear Upper Strutbar
[ ] - Rally Series Lower Truss Bar
[ ] - Rally Series Lower Tiebar Set
[ ] - Front Strut Bar
[X] - DynoMax, SuperTurbo Axel-back
[X] - HomeMade Oil-Catch Can
[X] - TB Radiator Hose Eliminator
[X] - HID kit, 8000k
[X] - Rear Lence in red
[X] - Static Side marker Amber color
[img]http://i166.photobucket.com/albums/u83/izkierdo/IMG_1404-1.jpg[\img]
