Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 16, 2007, 07:48 PM   #1
Personal Sales Rating: (0)
Drives: 08 Lancer GTS
RRM Piggy Back ECU - Question
How easy is it to connect the module and disconnect it in case I have to take my car in to get it serviced?
My other question is probably best answered by someone at RRM, once I disconnect the module is there any trace of it being there left on the ECU? Basically I'd like to know if my dealership will be able to tell that I tinkered with the ECU...
Thanks a lot
Offline
Old Dec 16, 2007, 08:02 PM   #2
Nosman's Avatar
Drives: 2008 Lancer GTS
Fairly easy to install and remove , no they can't tell if you tricked the ECU but YES they will see the spliced wires . Use at your own risk .
Offline
Old Dec 16, 2007, 08:05 PM   #3
Personal Sales Rating: (1)
nj_08_gts's Avatar
Drives: TB 2008 Lancer GTS, Spec Miata
Send a message via AIM to nj_08_gts
Thanks a lot
It's a pretty easy install and as far as taking it off for service you have 2 options: hide it well so that you don't have to worry about it or buy some 5 cent connectors at Radio Shack to make it easily removable. It may even come with the connectors do do that...somebody with the piggyback could give you a 100% answer.
There wouldn't be any trace if you disconnected the piggyback...it's not as though it hacks into and alters the ECU or anything, so you're safe there.
__________________
"Speed has never killed anyone - suddenly becoming stationary, that's what gets you."
- Jeremy Clarkson
Offline
Old Dec 17, 2007, 02:46 PM   #4
Really? I had heard otherwise; that the ecu actually keeps records the air/fuel mix and that if it is plugged into diagnostics, if the tech is looking, they can tell and will know that a piggyback was used at one time. I wish I really knew 100% for sure. Oh well.
Offline
Old Dec 29, 2007, 11:48 PM   #5
my only problem with the piggyback is that my mechanic says the clips that come with it are crappy and will sometimes not keep a secure connection. He said it is better off to solder the wires which will not be easily removabe wen u go tp the dealership...
does anyone know a beter wasy?
__________________
08 GTS F/L
[ X] RRM intake
[ X] RRM pulley
[ X] tinted headlights
[ X] non- scratched tints
[ X] Debadged rear
[ X] 18' enkei evo 5's
[ X] RRM rear swaybar
[ X] smoked tail lights and side markers
[ X] RRM rear sway bar
[ X] tein s-techs
[ X] RRM test pipe
[ ] a good paying job
Online
Old Dec 30, 2007, 05:56 AM   #6
FinestSoldier's Avatar
Drives: 2008 Lancer gts Electric Blue
I solder them but i taped up my wires and i taped up the piggy and hid it. It looks completly stock. Did it nice and neat .
Only way i recommend
Offline
Old Dec 30, 2007, 10:15 PM   #7
Drives: 2008 lancer gts
Quote:
If there is a Check engine light, the ECU will record the conditions that set the light. Then the technician can see different parameters such as fuel trim and timing. Most likely He won't know that it was caused by a piggy back but if the harness has been tampered with then it might not be covered by warranty. However if you in for a suspension problem there is probably no reason for the tech to even hook up the scan tool to it.
Offline
Old Dec 31, 2007, 11:53 AM   #8
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
Solder them.
Trust me, even if you use the clips, will be able to tell you've tampered with the car.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Jan 2, 2008, 02:22 PM   #9
2008 Mitsubishi Lancer
evo_soul's Avatar
Drives: Lancer 2008 GTS
lol they know all, (all seeing eye)
__________________
Current MODs:
XenonDepot 3000k (Low) - Injen CAI - Custom 2.25" Dual Exhaust - Side License Mount - HOS Urban Fr and Rr Lip - Tints: 22% 5% - LED Side Mirror - 18" MSR Style 045 - Scorpion V-LIP - 3 Piece Spoiler - ASW 4-2-1 - KVR CF Brake Pads - KVR J Hook Rotors (Silver)
Next:
XenonDepot HID 3000k (fog) - ASW Engine Dampener
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
Online
Old Jan 2, 2008, 04:54 PM   #10
nj_08_gts's Avatar
Quote:
__________________
- Jeremy Clarkson
Offline
Old Jan 2, 2008, 06:11 PM   #11
EvoM Moderator
NJ deserves member of the week.
__________________
Modern Warfare 2
Offline
Old Jan 11, 2008, 09:37 AM   #12
M@verik's Avatar
Drives: Nissan Xtrail, Mitsubishi Lancer 2008
lol luckily my mitsu dealership turns a blind eye to mods, since they do it themselves
Offline
Old Jan 24, 2008, 05:20 PM   #13
Ironballz's Avatar
Drives: 2008 Lancer SE
Quote:
Lucky you! My dealership isn't too bad. They said as long as they can't prove the mod caused the problem then it's warranty safe.
I've seen much worse dealerships...my friend's Nissan dealership told him he couldn't' even install an after market CD player without voiding his warranty!
Anyways, back on topic...I really would like the piggy back but worried about the possible consequences with warranty...I have a feeling the piggy back might be pushing it a bit too far with my dealership...doesn't hurt to ask I guess.
Offline
Old Jan 25, 2008, 09:01 AM   #14
SeRious08's Avatar
Drives: Boosted 08 Lancer GTS
Its not that hard to install it where you can remove it within a 15 minute time frame.
Offline
Old Jan 25, 2008, 05:42 PM   #15
Ironballz's Avatar
Quote:
Ya but you have to splice into the wires right? I'm worried they'll void my warranty if they see the spliced wires.
Offline
Tags
2009, ecu, instructions, lancer, piggy, piggyback, rrm, tuning, wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
