Sep 16, 2007, 05:50 AM
Personal Sales Rating: ( 0)
Drives: Lancer 08
Any one has tried an SAFC so far?
Apex'I Super AFC II SAFCII (Digital) Fuel Computer
The A'PEXi Super AFC is the industry standard for sub-computer fuel control. It is designed to fine tune and squeeze power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make horsepower, the S-AFC allows the airflow meter/pressure sensor signal voltage going to the factory ECU to change the amount of fuel injected. It utilizes a VFD (vacuum florescent display) to display critical data in three different modes; numerical, analog, and graph.
Numerical mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. Analog mode displays up to two valued in an easy to read meter style display. Peak hold is also included in this function. The graph mode offers real time graph plotting with a ghost map trace feature built in. The graph can replay movement up to 60 seconds.
Also displays:
Air Flow Capacity
Engine RPM
Throttle Position
Pressure Sensor Voltage
Karmann Frequency
Air Flow Meter Correction
Tech Notes: The AFC comes preprogrammed with most of the commonly used airflow meter/pressure sensor maps. By setting the AFC to one of these base programs, the user is able to adjust injected fuel mounts by +/-50%. Eight user defined RPM adjustment points allow maximum tuning in 500-RPM increments. Fuel can also be adjusted for part and full throttle situations.
Model#: APEX-401-A911-S
Pros Cons any one any thing , just came apon one in ebay so opinios!
Offline
Sep 16, 2007, 07:36 AM
2008 Mitsubishi Lancer
Drives: Lancer 2008 GTS
i am sure its possible with the Manual transmission, but the CVT may freak out if something trys to override it.
That CVT has a brain as big as the primary ECU.
__________________
Current MODs:
XenonDepot 3000k (Low) - Injen CAI - Custom 2.25" Dual Exhaust - Side License Mount - HOS Urban Fr and Rr Lip - Tints: 22% 5% - LED Side Mirror - 18" MSR Style 045 - Scorpion V-LIP - 3 Piece Spoiler - ASW 4-2-1 - KVR CF Brake Pads - KVR J Hook Rotors (Silver)
Next:
XenonDepot HID 3000k (fog) - ASW Engine Dampener
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
Offline
Sep 16, 2007, 10:21 AM
Personal Sales Rating: ( 88)
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
I've heard that it's not compatible with the 2008 because of the ECU. But I haven't seen any hard data on that yet.
I'd love if it worked. It's nice to have just for the data it shows (speed, RPM, knock, etc).
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Sep 16, 2007, 10:36 AM
Drives: 08 Lancer
I had one of these before, i think it was the 1st Generation one but then my car was automatic at that time so i sold it on ebay. hehehe if i only knew. anyone knows if this is compatible with our 08's?
Offline
Sep 16, 2007, 11:21 AM
Personal Sales Rating: ( 1)
Drives: 2008 Lancer GTS
Id rather use Emanage
Offline
Sep 16, 2007, 12:08 PM
Drives: 2008 lancer
It should work, it simply alters the MAFS signal like other piggy backs. Some features like the the knock reading and such may not work, but it didn't work on the 2g eclipses either.
Offline
Sep 16, 2007, 03:34 PM
Drives: Lancer GLS 2008
i simply don't quite swallow those aftermakert computer and piggyback things...if a matter of small programming can make the engine more fuel efficient while at the same time more powerful, why oh why wasn't this tuned at the factory???
Since it's a matter of tuning, it shouldn't cost the factory any extra thing.
So i am putting my money on the factory settings coz i trust they are the best
Offline
Sep 16, 2007, 06:02 PM
Drives: Lancer 08
en the 06 rallyarrt it did wonders but it is compatible with 08 computer?
Offline
Sep 16, 2007, 06:46 PM
Tuning wise you would get far better results with an Emanage or Emanage Ultimate over the SAFC2, u can do more with it for about the same price
Offline
Sep 16, 2007, 07:08 PM
 isn't tuning a racecar. They're tuning a family-friendly econobox that they can sell to a 16-year-old OR his 88-year-old grandmother. They tune for a happy mix of HP and MPG. The people on this forum tune for HP only. Comfort and MPG be damned.
Factory settings are not "the best." They're a happy medium. I could use an SAFC and make my car more powerful AND more fuel efficient than it is now.
__________________
Modern Warfare 2
Offline
Sep 16, 2007, 07:32 PM
Nice, was gonna say the same thing but u beat me to it
Offline
Sep 17, 2007, 04:38 AM
Drives: Lancer 08
 nice !
Offline
Sep 17, 2007, 03:47 PM
Quote:
Originally Posted by evo-monstar
 nice !
I can't tell if you're agreeing with me or not.  But that's how business works. The Lancer is a car for anybody. That's why you see a lot of folks with gray hair driving them...
__________________
Modern Warfare 2
Offline
Sep 17, 2007, 03:57 PM
Personal Sales Rating: ( 12)
Drives: 03 evo VIII, 87 Grand National
Not only that, Mitsu tunes them down to have a higher level of reliabilty withthere cars.
If everyone of them was tuned to the max, there would be a lot more failures, warrenty issue's.
Offline
Sep 17, 2007, 04:31 PM
Drives: Lancer 08
is sounds so funny but at the same time its so friking true, and yes i would like to get out of this engine in a NA state about 300 Hp! thats my goal!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
