Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Apr 22, 2007, 08:07 PM   #1
Former Vendor
Personal Sales Rating: (28)
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
Send a message via AIM to crypto Send a message via MSN to crypto Send a message via Yahoo to crypto
Question Piggyback CEL (i've already searched w/ no luck)
(sorry wrong section. Mods please move. Thanks )
Ok, i did a lot of searching and haven't found any real answers. Also i have already emailed RRM several times and even called, it seems they are really busy so i haven't heard back from them.
I have installed my V1 Piggy Back on my auto OZ.
the power has finnally kicked in, and my MPG have went up, (260 for a full tank) So i know the piggy is working.
I have triple checked my connections, they are soldered up. And all my vacumn lines are zip tied.
I have a vacumn guage, i'm not sure what it is supposed to read, but it reads around 20 when i'm at idle, and at WOT it is just under 0.
Anyway. I have a CEL, 3 codes have been thrown
2 for running lean
1 for a bad O2 sensor.
these lights only came on after i had installed the piggy. I have reset everything 3 times now and it's not going away.
Here are my engine mods
RMR SRI, FPR, Mirage Underdrive Pulley, Engine mounts, Engine damper, Testpipe
The car is running fine. The idle is a little rough,. but not bad enough to cause concern, cos i know a bad idle is kind of expected with a V1 piggy. Also when the car shifts, it seems a little rougher than usual.
Any help would be appreciated. Saying as RRM are understandably busy right now.
Last edited by crypto; Apr 22, 2007 at 08:10 PM. Reason: wrong section, i'm an idiot. The one downside to tabbed browsing, its tough to keep track of pages
Offline
Old Apr 23, 2007, 06:04 AM   #2
Personal Sales Rating: (8)
Garage is empty, add now
blaze_125's Avatar
Drives: Yellow OZ
I still think you should put the stock FPR back in and see.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Apr 23, 2007, 07:40 AM   #3
Former Vendor
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
Quote:
i hade the same CEL before i changed out the FPR, so i know it isn't that. Plus, if that was the problem, i would get a CEL for running rich if anything, not lean, cos the FPR is set at a higher PSI than stock
Offline
Old Apr 23, 2007, 11:20 AM   #4
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: 2004 Ford Explorer
DJ zero 1980 Blacksheepdj
Moved for ya.
Any thought of actually changing the O2 sensor? They do die, you know. It might have just been a coincidence that it did right after the PB install (maybe the new A/F learning fried what little life it had left?).
__________________
Currently playing:
PS3 - blacksheepdj - Journey
PS Vita - blacksheepdj - Uncharted: Golden Abyss
XBL - DJ zero 1980 - Gears of War 3
Check out the Evom store!
Offline
Old Apr 23, 2007, 12:04 PM   #5
Former Vendor
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
Quote:
Originally Posted by Blacksheepdj View Post
Moved for ya.
that might be a good idea. You think if i unhooked the piggy and took it to the dealership they would do it under warranty? Cos i know they cost like $70 from autozone (non-OEM)
Offline
Old Apr 23, 2007, 12:16 PM   #6
Personal Sales Rating: (7)
radicaledward's Avatar
Drives: 2003 Lancer OZ
I think that the O2 sensor is considered a wear part - so odds are they will not swap it out for you.
Offline
Old Apr 23, 2007, 12:24 PM   #7
Former Vendor
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
argh. that sucks. Well i don't suppose anyone knows where i can get one for cheap? Just to test. I don't wanna buy one and still have the CEL and find my O2 sensor was fine to start with.
Offline
Old Apr 23, 2007, 12:29 PM   #8
Personal Sales Rating: (9)
atilla's Avatar
Drives: 02 OZ
Send a message via AIM to atilla Send a message via MSN to atilla
http://www.automedicsupply.com/catal...engine=L4-2.0L
those should be the O2 sensors for our cars. you might also want to try a MIL eliminator from http://www.mileliminatorsonline.com i used one to help get rid of my CEL when i put my header on and rounded the 2nd O2 sensor off so i couldn't do the mechanical fix on it.
who made your FPR btw?
__________________
my lancer!
RRM / R.I.P. Gabe
Offline
Old Apr 23, 2007, 12:32 PM   #9
Former Vendor
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
i don't have a header though. And the CEL was on before the Testpipe also. So i know thats not it.
I don't know who made the FPR, airlinevomitbag sent me it for free with the testpipe.
Offline
Old Apr 23, 2007, 05:45 PM   #10
Personal Sales Rating: (2)
Newfoundlancer's Avatar
Drives: 2003 OZ Racing Rally Edition Lancer
Send a message via ICQ to Newfoundlancer
http://replacement.speedyperformance...l=null&dp=true
Judging by the price differences.. I hope it's your first O2 sensor that's burnt out if you end up going with these guys
OR:
http://www.carpartswholesale.com/cpw...1&make_code=MI
OR:
http://www.car-stuff.com/mmparts/mit...en_sensor.html
Offline
Old Apr 29, 2007, 07:34 AM   #11
Personal Sales Rating: (5)
wOZrally's Avatar
Drives: 03 lancer oz rally
as for running lean. i threw the same code and most of the time all you have to do is clean the MAF sensor. take it off get some break cleaner and spray it. put back on when completely dry
Offline
Old Apr 29, 2007, 02:14 PM   #12
Personal Sales Rating: (1)
iufan4lifeul's Avatar
Drives: 2002 Lancer ES
Are you sure that you have the RRM tune on there? The piggyback is VERRY sensitive and LOVES to throw CEL's.
__________________
2002 Lancer ES. Automatic
Engine- RRM Ported and Polished Head, RRM Stage 1 camshaft, RRM Ported IM, RRM Ported TB, RRM crank pulley, custom SRI w/K&N Filter, RRM Header, NGK V-Power plugs, NGK spark plug wires, Apexi SAFC Neo, 2.25" custom exhaust, 2.25" downpipe, magnaflow resonator, magnaflow HFC, and Greddy muffler
Styling- OZ spoiler, Enkei RS5 16" rims with Hankook Ventus 205/40/16 tires, Progress springs
Offline
Old Apr 29, 2007, 02:17 PM   #13
atilla's Avatar
Drives: 02 OZ
they make a cleaner specifically for MAF sensors... it's made by CRC and it's in a grey can. if you're going to clean the MAF use that.
__________________
my lancer!
RRM / R.I.P. Gabe
Offline
Old Apr 29, 2007, 02:34 PM   #14
Personal Sales Rating: (17)
2002 Mitsubishi Lancer
WangMan's Avatar
Drives: 02 OZ Rally
WNGR
Send a message via AIM to WangMan
Even if you the cel came on before the testpipe, your gonna have trouble turning it back off without that cat. Doesn't RRM sell a 20 dollar piece that tricks the o2 sensor into thinking the car filters enough fumes even if its not?
__________________
Wang's OZ Rally
Offline
Old Apr 29, 2007, 05:21 PM   #15
Personal Sales Rating: (4)
Redlancer's Avatar
Drives: 2003 Lancer ES Red
2 for running lean
Those 3 code came from a bad fonctionning 02 sensors... (P0171 if I remember...) I got a problem like that when my car it 65 000 miles and I chage my o2 sensors and all came back great.
I hope that will fix your problem too.
__________________
Progress Sway Bar + Sway bar perches
Ralliart complete suspension
R1 Drilled Sloted Rotor
Kevlar Brake Pad
ASA EM9 17" wheel
UDP Pulley
TWM Short Shifter + Classic knob
Magnecor Spark plug wire
Deyeme Firm Motor Mount
JDM Cedia Ralli///Art Front Grill
RMR SRI
Custom made:
Front & Rear K-BAR
Ported Intake Manifolt
Oversize fuel Rail
Ecuflash custom tune.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
08, 2008, codes, gti, lean, mkv, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
