Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 15, 2006, 11:26 AM   #1
Personal Sales Rating: (0)
04T-WRX's Avatar
Drives: 04 WRX
Open loop closed loop
I know nothing about the Lancer ECU so take it easy on me.
This ECU does have an open loop mode correct?
If so at what RPM range/throttle position does the open loop mode turn on?
If the car is an automatic does that make a difference or does it make a difference depending on what gear the car is in?
On my subaru the car goes into open loop as low as 3000RPM's but only in higher gears because the throttle has to be at 100% for 2 seconds, in lower gears it comes on around 4500 I think, is a lancer like this?
The reason I am asking is because I have a piggyback ECU that could be hooked up to my G/Fs lancer while I upgrade to a more subaru specific ECU and am wondering how this one might work on her car. There is still a LOT more I need to look into but figured I would start with this.
-Travis
Offline
Old Jan 15, 2006, 04:41 PM   #2
Personal Sales Rating: (5)
Johns Slow ES's Avatar
Drives: 05 GTI
what kind of piggy back is it? if it was made for a subarus i wouldnt just plug it into the lance cause it would have a different setup then ours and most likly mess something up unless it tuneable then u can search and find out info from Hobie and other more knowagleable people what u can set it at
as for the open close loop thing might want to ask boe or hobie they have messed w/ around w/ tuining a lot more than i have
__________________
Please check out my part-out thread
Click Here
Check out Blingo a cool search engine that lets u win stuff for using there site!
Offline
Old Jan 15, 2006, 07:03 PM   #3
Personal Sales Rating: (9)
WADADLIG_OZ's Avatar
Drives: US Lancer OZ sold, EVO II
It's Hobie Kopek and Boe is a no show anymore.
PM Alchemist although he is scarce but he would also be a good source of knowledge.
WADAD
__________________
Back in the island of Antigua aka Wadadli
EVO II GSR
MODS
KN filter and adapter.(6inch)
3inch TBE
New suspension
13.991 @ 96.57mph
13.561 @ 101.12mph
13.384 @ 102.04mph NEW BEST 1.899 60foot :(
Man I'm slow!!!
Offline
Old Jan 15, 2006, 10:11 PM   #4
Personal Sales Rating: (6)
03RallyLancer's Avatar
Drives: Silver '03 Lancer O.Z.
Send a message via AIM to 03RallyLancer
what pb do you have... i dont know exactly when it swiches over between loops as i havent gotten the digimoto yet... but im sure it is very close to your suby ecu in its switching between loops
__________________
Awaiting Install:Boe's Fuel Rail; Kartboy Base Bushings; NSN Gauge Panel; and Progress Camber Kit
Next to Buy:Digimoto
FInally gonna start tuning the eManage!!
The answer to all Lifes questions
For Sale:Stock Parts and Custom Chopper
www.speed-society.com
www.lexistreets.com
Offline
Old Jan 16, 2006, 12:39 PM   #5
EvoM Administrator
Personal Sales Rating: (8)
HobieKopek's Avatar
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Send a message via AIM to HobieKopek
Yes, the Lancer (and all OBDII cars as far as I'm aware) run in both open and closed loop depending upon sensor responses. I'm not sure the conditions for open loop on the stock ECU (mostly because I don't have one), but I doubt it's much different than any other car. Did you need to know anything specifically? Some people have had problems with piggybacks on the Lancer (mainly that the PB's changes wouldn't "stick") but others have had great success.
__________________
Quote:
Originally Posted by Foggy View Post
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Old Jan 18, 2006, 04:08 PM   #6
Personal Sales Rating: (23)
Alchemist's Avatar
Drives: Artemis: Lancer A-spec
Open loop, as far as I can tell (since I've never read anything definitive about it) happens at: 3000+rpm AND/OR 30%+ throttle (because cruising along maintaining speed takes very little throttle, something like 10%). So if you're cruising in 2nd at 5000RPM you're open and if you're doing 30 in 5th with your foot mashed to the floor you're also in open loop. this is the "fuel dump" mode but is also where your eManage type computers will be effective.
However, I have no info as to whether a traditional piggy will work on an AT or how it should be set up. I will recommend a "genuine" GReddy cable if you're using the eManage because the two clones I used (one I bought, one I borrowed) didn't work at all.
Offline
Old Jan 18, 2006, 04:12 PM   #7
i have a clone one that works well... i checked 3 weeks after i tuned and everything was holding... wont check again till spring...
__________________
www.lexistreets.com
Offline
Old Jan 18, 2006, 07:04 PM   #8
Personal Sales Rating: (3)
impetus19's Avatar
Drives: 03 lancer ; '79 CJ5 304
Send a message via AIM to impetus19
I concur with alchemist.. all of my wideband datalogs show my afr's dropping out of the 14.7 range (closed loop) after somewhere around 30-35% throttle range. It's pretty easy to tell because the ecu begins dumping fuel after that point.
__________________
Mods:
Kamikaze headers
Buschur intake
emanage
LC-1 wideband
ported 4g93 IM
rrm crank pulley
Offline
Old Mar 1, 2006, 06:57 AM   #9
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
For people still wondering about open/closed loop... I hooked up the Auterra this morning to refresh my memory and figured I'd share the knowledge.
OpenLoop: Pedal to the metal.
ClosedLoop: Cruising, slight acceleration with very little throttle
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Mar 1, 2006, 04:43 PM   #10
EvoM Administrator
HobieKopek's Avatar
You probably won't be able to determing the open/closed loop transition point without seeing the ECU's parameters. There are SO many maps and trims that all overlap one another. I'm guessing RPM, load, AFR, TPS value, coolant temp, acceleration fuel trim (on top of TP), air intake temp, and sensor malfunction are all involved in determining whether the car runs in open or closed loop. These are just bare minimums that I can think of off the top of my head, but I'm sure there's even more. Some may override the rest in certain situations (stomping on the accellerator from idle or a sensor malfunction could both potentially put the car directly into open loop for example). There is a LOT of overlap that goes into the calculations determining this sort of status.
__________________
Offline
Tags
addison, cable, close, closed, diy, ecu, emanage, installation, loop, open, running, start, support, tuning, yahoo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
