Go Back   evolutionm.net > Lancer Forums > Lancer Audio and Security (All models)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 16, 2004, 06:57 AM   #1
Personal Sales Rating: (4)
ebbeast2005's Avatar
Drives: evo 8
Send a message via AIM to ebbeast2005
The best way to ground aftermarket cd player
I Hooked up my clairon headunit and there is no ground on the stock head unit from what i can tell. I ran the ground from the headunit to a bolt and i blew the fuse for the rear tailight and lights for the nobs for the a/c. What is the say way to do it? The only thing i can think is im going to install my tv & dvd so i was going to run a ground from the battery into the car. Is there any easyer ways
Eric
Offline
Old Feb 16, 2004, 07:50 PM   #2
Drives: evo 8
any1?
Offline
Old Feb 16, 2004, 07:55 PM   #3
Personal Sales Rating: (2)
mboza79's Avatar
Drives: 2002 mitsubishi lancer oz rally and a 1992 z24 cavalier
Use a seft tapping screw or drill a hole in a metal bracket behind stereo and ground it there. Do not run wire from front of car to behind dash as this would be a very poor ground because of the small wire guage I would assume you are using. You should have not blown any fuses asyou said you did. Make sure you are using the proper wires man or you can do some damage. Oh, and of course, make sure the power is off on vehicle when doing your wiring.
Offline
Old Feb 16, 2004, 07:59 PM   #4
Personal Sales Rating: (0)
akaflakes's Avatar
Drives: 03 zx2 mtx now with mods
Send a message via AIM to akaflakes
the stock headunit has a ground. nothing can draw power with out one.
__________________
I type in Lancerforums.com and it brings me here. strange.
Offline
Old Feb 16, 2004, 08:14 PM   #5
Drives: 2002 Lancer OZ
Send a message via AIM to rhitme03
I ran a wire behind the console and to the mounting bolts for the gear shift... Other option is to run the wire to the "Cigar Plug" and splice into that ground.
Good Luck!
__________________
Remote Start On a Manual... YES... It can be done... It even won't start while in gear!
Offline
Old Feb 16, 2004, 08:21 PM   #6
Personal Sales Rating: (10)
timdog4life's Avatar
Drives: 2003 Lancer ES
Send a message via AIM to timdog4life
I had the EXACT thing happen to me about 3 days ago. I hooked up my alpine and I blew the same fuse you did. After replacing the fuse everything works fine now....
I ended up grounding the headunit to one of the bolts directly behind it. When the HU isnt in yet and your looking into the hole in your dash you might notice 4 bolts that look like they might be bolting your dash to firewall (or at least something else sturdy)
All I did was loosen one of those bolts and attach the ground to it and then put everything back the way it was....
__________________
Here's a cool website where you can fill out surveys to get Xbox360 and Wii stuff.
I've already received a free Wii controler. Click here to sign up.
Enjoy the free stuff!
Offline
Old Feb 17, 2004, 06:39 AM   #7
UglyAngelX's Avatar
Drives: 03 OZ/GSXR-750
Send a message via AIM to UglyAngelX
I did the same thing as TimDog and have no problems with noise or anything else. Just get a small ratchet and loosen one of the bolts directly in back of the unit, it looks like it is holding some of the bracing in place, it is ok to loosen one and have the bracket remain in place. Watch your hands in there, it is a little bit tight and I have a nice scar on my finger to prove it.
__________________
It all makes sense at 170 mph.
Offline
Old Feb 17, 2004, 08:19 AM   #8
Personal Sales Rating: (1)
Drives: 2002 Lancer ES, 2002 Honda CBR954RR
Quote:
+1
I installed my Kenwood last night and did the same thing as above. No problems whatsoever last night or this morning. I installed a ring terminal on the ground wire and put the bolt right through that so it makes good contact.
__________________
2002 Lancer ES, Thunder Gray
2002 Honda CBR954RR
10.55 @ 133mph, bone-stock
Offline
Old Feb 17, 2004, 08:33 AM   #9
OZLancerlunatic's Avatar
Drives: 2006 Infiniti G35x
Send a message via AIM to OZLancerlunatic
OR, if you want to do it really nice, grab the factory harness, take a look, find the ground, splice into that and there you go, a nice ground.
__________________
I'm the best there is, plain and simple. When I wake up in the morning I piss excellence.
Offline
Old Feb 18, 2004, 08:07 PM   #10
Drives: evo 8
ok i totally re wired the harness wire for wire and I ran a ground to a bolt, it blew...Ran it thru the antenna which is what grounds out the stock 1 it blew.... Tryed no ground just the harness to the harness it blew. Ive had people who kno there **** look at it and were all stumpt... Some one tell me exactly how they wired up there cd player after wireing harness to harness. Im using a 2002 Lancer harness..Im lost
__________________
Mods:
PTE 60 trim turbo ,Megan Turbo-back & delete,Tial bov ,injen intake, upper i/c pipe,Greddy profec bII, AFC2, FLash,680 injectors, Walbro 255, ACT clutch,Tubular manifold,Megan FMIC.
http://www.cardomain.com/ride/2064004/1
Offline
Old Feb 18, 2004, 08:15 PM   #11
Personal Sales Rating: (5)
bobaab's Avatar
Drives: 91 MR2 NA
Send a message via AIM to bobaab
u know, i had a weird experience with a cd player installation in this car..i dont think i ever hooked up my ground..or one of the power wires i remember and it still worked. i was using a mitsubishi harness.
and im not a newb when it comes to installation, i know for a fact that the ground wasnt connected when i tried to see if everything was hooked up. i eventually did just ground the cd player to some bolt behind the console tho.
__________________
Signature flush.
Offline
Old Feb 18, 2004, 08:29 PM   #12
Personal Sales Rating: (17)
EvilBlueEvo8's Avatar
Drives: '03 BBY CT9A GSR Vishnu V390
Send a message via AIM to EvilBlueEvo8
ebbeast2005,
Ok here is the real deal. The lancer radio is an iso mount radio (meaning is mounts with brackets instead of a cage) and ground is transfered from the stock radio chassis through the radio brackets and then through the mounting posts and etc, back to the battery. Anyways this is how you do it. Take the ground wire that comes off the Clarion harness and then put a ring terminal on it (make sure you have enough wire length) and then take off one of the screws that you mounted the radio to the iso brackets with (I suggest one of the rear screws). Screw it back into the bracket with the ring terminal inbetween the screw head and the bracket. Now screw your radio back into the mounting posts. Assuming you've replaced your fuses that you've already blown before, your Clarion should power up (also assuming you've wired the rest of the harness correctly). PM me if you need more help/have any other questions. Oh and there are two Mitsubishi harnesses. One for up to 93 or 94 (I forget) and one from 93/94 to the present. You should be using the one for the 93/94+ models.
__________________
2003 BBY CT9A Evolution GSR Vishnu V390 - Made in October 2003. Bought March 25, 2004.
2004 MS CS6A OZ Rally - Stock
2002 Durango SLT 5.9L - Stock with 3" lift and K&N
My Page:
http://www.cardomain.com/ride/709068
Offline
Old Feb 18, 2004, 08:32 PM   #13
Oh and here is another tip, don't hook up the Illumination and Dimmer wires (orange and orange/black) because on many cars they will just cause problems with blowing fuses and could be one of your other problems. Just cap them off seperately. It's standard procedure at my shop not to connect them to prevent unneccessary problems.
__________________
My Page:
Offline
Old Feb 19, 2004, 07:47 AM   #14
When I did mine, I hooked up every wire but the 2 for the power antenna and 1 for a "cell phone mute" option. Make sure you solder and shrink wrap all the connections for best results.
__________________
2002 Honda CBR954RR
Offline
Tags
cd, ground, player, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
