Jul 22, 2009, 08:58 PM
Personal Sales Rating: ( 2)
Drives: 2008 Mitsubishi Lancer GTS
Viper alarm problem
so, i have been out of town for a month or two.. and my parents tried to move the car, but the alarm kicked in. My mom said that she did not lock the car the last time that it was moved. now my car won't start.. any suggestions?
__________________
Post # 222,222 on APW
XBL tag: PANDAmonium702
Quote:
Originally Posted by andyktlee
Herro? My name Byung with Areejona. I call to ask *CLICK*
Herro? Herro?
Offline
Jul 23, 2009, 03:56 PM
Personal Sales Rating: ( 6)
Drives: Boosted 2008 Mitsubishi Lancer
charge your battery
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Jul 23, 2009, 04:15 PM
Personal Sales Rating: ( 0)
Location: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Drives: 08 Yamaha R1/06 Evo IX/99Yamaha R1
Has your car got juice? Do the lights turn on and all that or is it the actual alram system not allowing you to crank?
Offline
Jul 25, 2009, 07:24 PM
i am currently out of state right now.. if my battery was dead, would that affect the alarm? apparently the keyless fob was not communicating with the alarm system....
__________________
Herro? Herro?
Offline
Jul 29, 2009, 08:02 PM
Personal Sales Rating: ( 1)
If the vehicle battery is not dead, turn the ignition on and push the valet switch once. That should disarm the alarm if it is armed and not responding from the remote. This will reconnect the starter kill relay and allow you to start.
If the vehicle battery is dead, charge it and refer to above.
If all else fails, unplug the main brain to the unit and try starting.
Offline
Jul 30, 2009, 07:25 PM
could the alarm system drain my battery if i have not turned the car on for quite a while?
__________________
Herro? Herro?
Offline
Jul 31, 2009, 07:41 AM
re:
It shouldn't be if installed and wired correctly.
Were you able to disarm the system and start the car yet?
Offline
Jul 31, 2009, 11:32 AM
i am still out of town until august 12th.. right now my parents just disconnected the battery... so who knows what else they did to shut my alarm up lol
__________________
Herro? Herro?
Offline
Aug 3, 2009, 07:42 AM
If installed properly these units are pretty reliable... if there is anything else aftermarket that you have in the vehicle it is more likely that something else caused the battery to drain. How long has the car been sitting without being started... because every electronic accessory has some sort of drain on it's constant power wire... in most cases it is a very low amperage draw that you never notice it... until you leave your car for a few days or weeks and then it won't start.
Offline
Aug 6, 2009, 12:01 AM
yeah i have an aftermarket navigation system and an amp.. that might have done it.. the car has been sitting for 2-3weeks without being started
__________________
Herro? Herro?
Offline
Tags
alarm, battery, car, draining, fob, fs, ignition, issue, opening, problems, start, starting, turn, viper, wont  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
