Go Back   evolutionm.net > Lancer Forums > Lancer Audio and Security (All models)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 2, 2009, 07:34 PM   #1
Personal Sales Rating: (0)
Has any one used Scosche dash kit??
Hi Guys,
I have just got a Pioneer DEHP6050P head unit and thinking getting a dash kit now. Need some help guys. Has any one used Scosche MI3019B dash kit.
Please can you post pic if you have used this kit.
I have a few questions, please share your comments.
How does it fit
Does it match with rest of the dash.
Does it come with brackets and other fittings(so that i can put a single din unit in it)
I know JDM one is a perfect match but with current Australian $ it cost around 400$(bit expensive).
Thanks
Tama
Offline
Old Mar 3, 2009, 07:46 AM   #2
Drives: 2008 Lancer ES
I've heard from everyone that the Scosche is 100000 times better than the Metra one. I'm doing my install today with the Scosche. I'll up pics after I'm all done. It may not be until tomorrow since I'm doing a lot more than just the headunit.
Offline
Old Mar 3, 2009, 07:24 PM   #3
Hi OniLancer,
Thanks for your reply. Please do post pic's of your install once you are done.
Thanks
Tama
Offline
Old Mar 3, 2009, 09:40 PM   #4
Hammerfeind's Avatar
Drives: '09 Lancer GTS MT
I bought the Scoche Kit off of Ebay for $40. Overall I'm happy, my only grip is the top gap is about 1mm. Most people dont notice but I do so bugs me . If you press down on the dash i goes away, still trying to figure out a way to keep the dash pressed down.
Yes i can use a single din design. it comes with a pocket to put under the single din radio. And you use the factory mounting brackets so the radio is nice and solid, color match is spot on. Looks factory....Other than the 1mm gap. I recommend it!
if you get it, use very fine grit sand paper around the edges of the kit to get rid of the manufacturing ridges. oh and the clips that come with the kit work well but are not as good at the factory clips. if you have to take the kit back off for some reason a couple of the clips stay in the dash and then fall under the dash... pain in the ass so just make sure your done with everything before you snap it in place.
Tomorrow Ill take pics so you can see it in!!!
Offline
Old Mar 4, 2009, 01:17 AM   #5
2008 Mitsubishi Lancer
Tadz0rz's Avatar
Drives: 2008 Mitsubishi Lancer ES
I have the exact same headunit and dash kit. only thing that annoys me is that i have a little gap below the headunit.
__________________
Exterior --
Blacked Out Grill for evo look
Side mounted licence plate
Spoiler
Neon Front Grill
Engine
Road Race Motorsports Short Ram Intake V2
Sound System
Kicker zx400.1 amp pushing 475 max
2 12" Kicker Comp Subs
Rear speakers - Kicker KS600
Front Speakers - Kicker KS602 with splits
Pioneer DEH-P6050UB head unit
See more pictures of my ride at
www.myspace.com/tadz0rz
-- The RiceBurner --
"My Subs Hit More Lows Than Britney Spears"
Offline
Old Mar 4, 2009, 03:34 AM   #6
Hi Hammerfeind
It would be nice to see those pics, thanks for it.
Offline
Old Mar 4, 2009, 07:27 AM   #7
Personal Sales Rating: (1)
Drives: Evo X
i installed the Kenwood DNX5120 with the Scosche dash kit...couldn't be happier.
(i have some install pics if you're interested)
Offline
Old Mar 4, 2009, 05:03 PM   #8
Hi Kingu,
Thanks for your reply. If you dont mind could you please post more pic's of your install.
Thanks
Tama
Offline
Old Mar 5, 2009, 09:59 AM   #9
Drives: Evo X
***DISCONNECT BATTERY BEFORE BEGINNING!!!***
remove glove box
remove this screw and pull off the trim piece (carefully but forcefully)
remove this screw (same thing)
Offline
Old Mar 5, 2009, 10:04 AM   #10
Drives: Evo X
pull trim off
remove this screw
remove hazard/airbag thing-a-ma-jigger
unplug it (this was harder than it should have been)
Offline
Old Mar 5, 2009, 10:17 AM   #11
Drives: Evo X
remove the dash plate (carefull but forcefully...again)
remove the old stereo control ribbon from the hazard/airbag doo-hickey
remove the air vents from the old dash
snap vents into the Scosche dash
Offline
Old Mar 5, 2009, 10:25 AM   #12
Drives: Evo X
remove 4 screws and pull out old unit...unplug
remove mounting brackets
install bracket on new unit (may not mount same way. do a test fit before tightening)
at this point i did the wiring on my harness. obviously you could do it first if you want. i just needed a change of pace. i soldered the connections and used heat shrink tubing...i highly recommend do this.
plug it in, screw it down, pop all the pieces back in place and you're done.
it took me about 4-5 hours from start to finish, but after having done it once, i could probably do it in an hour and a half. pretty easy. i installed the gps antenna, xm radio kit and the ipod cable too...just didn't show them. i can if you need me to.
if you have any more questions let me know
B
Offline
Old Mar 5, 2009, 11:37 AM   #13
Personal Sales Rating: (6)
yitzac1990's Avatar
Drives: Boosted 2008 Mitsubishi Lancer
Send a message via AIM to yitzac1990 Send a message via MSN to yitzac1990
does the scosche kit also come with the pieces for a single DIN install? would a single DIN radio still use the factory brackets?
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Old Mar 5, 2009, 11:42 AM   #14
Drives: Evo X
Quote:
it comes with a piece (like a cubby box) that fills up the bottom part if you have a single din unit. not sure if the stock brackets will work though.
Offline
Old Mar 5, 2009, 07:53 PM   #15
Hi Kingu,
Thanks for posting the pics. After install it looks pretty good, matches with the dash prefectly.
Did you change the speakers also. If yes can you please post the pics for them also.
I just got my speakers, amp + sub and waiting for the dashkit to come. Then i can start working on my install.
Thanks
Tama.
Offline
Tags
08, 09, dash, evo, evolution, fit, install, kit, lancer, mounting, radio, remove, scosche, snap, x
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
