Go Back   evolutionm.net > Lancer Forums > Lancer Audio and Security (All models)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 20, 2009, 09:07 PM   #1
Personal Sales Rating: (2)
Lucas03ES's Avatar
Drives: 2003 Rio Red Lancer ES
Send a message via AIM to Lucas03ES Send a message via MSN to Lucas03ES Send a message via Yahoo to Lucas03ES
+12v constant messed up?
So I was messing around with my deck (Aftermarket Alpine), and when I put everything back together, the deck will not turn on. I am getting a switched power from the blu/yel feed to the wiring harness, but no constant (red/blk). Then, no clock, dome light, and the trip mileage keeps resetting on the instrument panel. Also, my aftermarket car alarm will only lock and unlock via key. Is there a possible fuse I could have popped for the 12v constant? I checked there is no stock radio fuse either. Thanks!
Offline
Old Feb 20, 2009, 09:13 PM   #2
Lucas03ES's Avatar
Okay, so after looking over some wiring diagrams I read that the red/blk from the radio goes to a 10 amp fuse under the hood (Bay 22, larger fuse box), but it and another 10 amp fuse are covered by a yellow case that will pull up, but not come off. It is right next to the ECU and I do not want to damage anything, how should I go about pulling these fuses?
Offline
Old Feb 21, 2009, 12:04 AM   #3
Personal Sales Rating: (6)
2008 Mitsubishi Lancer
yitzac1990's Avatar
Drives: Boosted 2008 Mitsubishi Lancer
Send a message via AIM to yitzac1990 Send a message via MSN to yitzac1990
either take it somewhere or figure out how to get those fuses out! sorry, thats all i can say man. i would go with option 2 though lol also, if you do that route, and its still messed up, definitely take it to a car audio place that also does alarms. they can fix it.
and off topic, but why did you need all 1/0 gauge and all that Dynamat for only 2 CVRs???
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Old Feb 22, 2009, 12:08 AM   #4
Lucas03ES's Avatar
Room to upgrade , and Dynamat was a must, trunk was making some noise.
Fuse was kinda odd, had to pull it out, and push two clips to the side that held each fuse down, then pull it out while holding the fuses in.
Offline
Old Feb 22, 2009, 12:18 AM   #5
Personal Sales Rating: (21)
ThunderOZ's Avatar
Drives: 02 Lancer OZ 16G TURBO
Send a message via AIM to ThunderOZ Send a message via Yahoo to ThunderOZ
That's weird, on my car, the red is the switched power wire and yellow is the constant...
__________________
-Merc
Build thread on Mitsu-Media
Cardomain
Offline
Old Feb 22, 2009, 11:43 AM   #6
Lucas03ES's Avatar
Quote:
You most likely mean the wiring harness you splice into the aftermarket head units, i'm talking the stock one where the constant is the red/blk and the blu/yel is the switched.
Oh yeah, it worked with a new fuse, thanks
Offline
Old Mar 20, 2009, 12:53 PM   #7
Personal Sales Rating: (0)
ljr4g94's Avatar
Drives: 2006 Mitsubishi Lancer ES
Now i have had this same problem once before. The fuse you want to look for is the dome light fuse which is inline with your radio fuse in the engine bay. To get them out, i had to use a set of pliers to get them out without breaking the yellow holder.
Offline
Tags
12v, 2003, box, constant, dome, ea4000, eclipse, entry, fuse, fused, harness, keyless, lightradio, mitsubishi, radio, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
