Feb 19, 2009, 07:44 AM
Personal Sales Rating: ( 0)
Drives: 2003 Lancer ES
12 volt noise filter
has anybody installed noise filter to the amp?
not with RCA wires but with just black and red wires..
im trying to install because I hear a high pitch buzzing sound when the car is on.
I took my car to the audio place and they want $65 for checking and seeing what the problem is, i don't want to spend that much money for this.
it's not the one with getting louder with acceleration but the sound is still and annoys my ear.
I tried to sand the ground again and separate the power cable with speaker cables but still did not work.. hmm
anybody?
Offline
Feb 19, 2009, 08:12 AM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
try a ground loop isolator ? i think they are like 15 bucks , you can probably buy one try it and if it doesnt solve the problem take it back.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Feb 20, 2009, 09:58 PM
i will try some
but i have a 5 channel amplifier which has 6 different RCA inputs from the headunit.
so do I have to buy 3 of the isolators?
Offline
Feb 20, 2009, 10:00 PM
Personal Sales Rating: ( 13)
Drives: TurboEs
Did you run the power wire and rca's on the same side of the car?
__________________
"In The Eyes Of A Blind Man, You Can See Everything"
Offline
Feb 20, 2009, 10:13 PM
no, that's the problem that I've fixed long time ago.
the sound hurts my ear..
I looked some online and installing it near the amplifier would eliminate the noise.
there are 6 rca outputs on my amp/headunit. 3 pairs of rca cables runs through from headunit to the amp. so.. do i have to get 3 of the isolator? or would one fix everything?
I grounded the ground wire to proper place, grounded all the paints off, and used short length of ground wire.
Offline
Feb 22, 2009, 11:46 AM
Drives: 2003 Rio Red Lancer ES
Is the noise coming out of every speaker that is amped, or just a certain single speaker or a pair of speakers?
Offline
Feb 22, 2009, 02:07 PM
I installed one ground loop isolator and the sound is almost gone.
I have 5 channel but I only used one.
but I still hear a little bit of noise not like before.
I saw some people online who installed 2 isolators for 4 channel speaker amp.
So I would like to try another one later.
Offline
Tags
12, 2009, amplified, antenna, audio, car, filter, filters, gts, lancer, lead, mitsubishi, noise, power, volt  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
