Feb 9, 2009, 10:07 PM
Personal Sales Rating: ( 0)
Drives: 2003 lancer oz rally
whats the problem?
I installed my amp and subs last week and am still stumped. All the wires are connected correctly but my amp still has no power. I grounded the wire by the spare tire under the mat in the trunk and sanded the area to get the paint off before i bolted down the wire. There's nothing wrong with the wire running from the battery to the amp. The fuses in the amp are good and the amp itself is good. i got it straight from a friend who used it the day before i put it in the lancer. so whats the problem? any thoughts would help.
Offline
Feb 10, 2009, 05:19 AM
Personal Sales Rating: ( 1)
Drives: 08 Evo GSR, 07 Outlander XLS
Stupid question but is the amp turn on wire connected? They sometimes call it the power antenna wire.
Offline
Feb 10, 2009, 05:26 AM
Personal Sales Rating: ( 16)
Drives: EVO VIII RS
^^ A quick check to see if the "remote" is correct is to use a little jumper wire and touch the Positive terminal to the remote terminal. If it turns on, your problem is your remote signal.
__________________
__________________________________________________
--------------- Tuned by "ONRAILS" ---------------
__________________________________________________ _
Offline
Feb 10, 2009, 05:39 AM
Personal Sales Rating: ( 2)
Drives: Evo VIII
It sounds like the remote wire. Re-check the fuses. Are u getting juice to the amp?
__________________
UDCustoms-----Fresh Designs Inc.
Redline Design Custom Graphics
Xceptional Auto Repair & Performance
50 Trim
Team $how$toppers
Offline
Feb 10, 2009, 05:40 AM
agreed, thats a good quick test.
Offline
Feb 10, 2009, 09:22 AM
Personal Sales Rating: ( 6)
2008 Mitsubishi Lancer
Drives: Boosted 2008 Mitsubishi Lancer
is the amp protect light on?
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Feb 10, 2009, 11:10 AM
thanks guys. its raining right now and i dont have a garage or one to go to so ill have to wait. as for the protect light, it came on then went off..... no idea.
Offline
Feb 10, 2009, 03:24 PM
Quote:
well make sure it stays off. if its on, and everything else is fine, then the amp is most likely bad.
__________________
240 whp
228 wtq
Offline
Mar 4, 2009, 11:58 PM
2003 Mitsubishi Lancer
Drives: 2003 Mitsubishi Lancer OZ Rally
you probably have a pile of **** amp, the protect light shouldn't of come on at all. Either the remote wire isn't hooked up right or try a new spot for you ground. I did mine right behind the back seat on a bolt under the matt
Offline
Mar 5, 2009, 01:28 PM
Drives: 2003 Rio Red Lancer ES
Double check to make sure you are getting a proper power and ground, I use a test light but you can use a multimeter too. Once that is done check the remote wire and make sure it is getting power when the head unit/source power is on. I have seen people connect the remote lead to the amp to the power antenna wire on the deck, and the subs only worked with the radio on, reconnected the remote wire to the proper lead and it worked fine no more problems.
Offline
Mar 7, 2009, 08:13 PM
Did you fix it?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
