How To: Installing Mitsubishi Aux/MP3 cable
Old Apr 9, 2008, 05:35 PM
  #46
Aiken's Avatar
^ok, so I found out that it's ok to remove them and replace them with the ones from the cable.
http://z3.invisionfree.com/2008_Lanc...topic=96&st=15
but still, anyone know what the pink, blue and black is for?
Old Apr 9, 2008, 06:59 PM
  #47
clearskies's Avatar
so... does this work for the 05 lancer. that site specified the aux adapter says to say what year lancer you have for them to send the "right" one...
so does that imply it will work??
i need help figuring this out....
i have an aftermarket unit installed. would this affect what is currently required to do with this aux cable.
Old Apr 12, 2008, 11:25 PM
  #48
IsaRic's Avatar
hey man, do u have the GTS without the sun&sound package? I do but im wondering if those wires are already there once u open it... is it? Did you have to buy the $50 cables?
Old Apr 13, 2008, 07:28 PM
  #49
elhombre57's Avatar
Question MP3/iPod connector problems
I own a 2008 Lancer GTS with the standard audio system. I have taken it to the dealer twice for installation of the MP3 cable, but they have been unable to get it working. Has anyone else encountered problems with this, or does anyone have any tips/suggestions as to how to make this work successfully?
Old Apr 13, 2008, 10:55 PM
  #50
Lancerion's Avatar
edited - never mind..........
Old Apr 13, 2008, 10:57 PM
  #51
Aiken's Avatar
I have the Canadian SE model, so I'm not sure if the GTS w/ SS comes with those wires. The cable I got was the one from Mitsu.
Old May 8, 2008, 12:05 PM
  #52
Onjisan's Avatar
Thank you very much for this guide.
Can you give me the correct model number for what you are using?
is it this: http://www.yourmitsubishipart.com/PD...aspx?MakeID=19
or
thanks
Old Jun 3, 2008, 07:16 PM
  #53
Papote's Avatar
Hi guys, I need help asap. My connector already has wires connected to it. Pink, blue and black. Anyone know what they are for? Thanks!
What type of terminal fits in the hole in that wire harness.
Found a AUX adapter but the terminal cut off.
Old Jun 10, 2008, 04:45 PM
  #54
sharmasir's Avatar
Will this work with '02 lancer, oz rally edition? My placer does not even have an Aux button, how will this work then?
Old Jul 15, 2008, 07:37 PM
  #55
mercury283's Avatar
Originally Posted by S.
Will the installation be the same if I have the Navi?
Can someone answer this? I'm in the same situation.
Old Aug 12, 2008, 06:37 PM
  #56
mercury283's Avatar
I finally got mine installed in my 2008 Evo MR. I have regular stereo system (not Rockford-Fosgate) and the Nav system (no tech package) does anyone have the problem of an ipod connected through this cable not being loud enough (I have to turn the volume on the ipod to max, and the stereo volume up to near max)?
Old Aug 22, 2008, 07:49 PM
  #57
tdanmorello's Avatar
I have an 08 GTS with S&S and had the dealer install the aux cable, I think just for the part price...cant remember if I paid for labor when I got the car. My ipod seemd to do the same thing volume wise when I tried it. Good thing I have the music hard drive . Haven't tried the ipod again after the first time and the feeling I paid money for a quiet ipod hookup lol. Oh, well might give it another go some time.
Old Aug 28, 2008, 05:55 PM
  #58
Lancer_GTS's Avatar
Ok everyone, clarification for everyone.
On the GTS models, the Pink, Black and Blue wires already in place of the radio connector are already connected to another piece further down in the dash.
Color codes are as follows
Pink = red
Blue = white
Black = black
All i did was splice into the existing connector found further below using the color combinations listed.
Here's pics of what it looks like, and how to get to it. (It's pretty much where the Factory rca plugs would be on the GTS w/ SS package).
Existing Harness:
Where it is located:
Looking closer (view looking straight down where stereo was taken out)
And for the record, I used a $3 cable, and it works just fine.
Old Aug 28, 2008, 05:57 PM
  #59
Lancer_GTS's Avatar
Forgot to check, but pretty sure the Green/Blue wire would be for a video option for those with a screen.
Old Sep 10, 2008, 03:09 PM
  #60
Fourdoor's Avatar
In the back of my C-109 connector I had a purple wire, a black with white stripe, and a black in the three pin positions needed for the IPOD adaptor. After reading a bit I just said "f it" and pulled those pins out and put the ones for the adaptor in place and put some electrical tape over the pins I removed. Any idea what (if anything) I disabled by doing this?
Keith
PS: Works fine, and volume level is great.
PPS: This is on an Evolution MR with base radio, no nav or 6 disk changer.
Quick Reply: How To: Installing Mitsubishi Aux/MP3 cable
