Quote:
Originally posted by AWD_Nut
i'm currently in asia,but from what i've been hearing is it true that it is easier to TC a DOHC than an SOHC engine.i dunno bout the kit i was hoping you guys could help me out btw could you explain more about the custom piping,wouldn't that take a lot of space???
I have seen turbo kits on SOHC engine achieved major success before. Basically, how you set it up is the major issue.
For older generations engines, the most important thing BEFORE going turbo is to make sure your engine is in optimal condition. Since it's a 10 year car. You might want to get a complete service/check up first, replace all the wear and tear....
RPW (racing performance warehouse??) worked on Mitsubishi for quite a bit, they might have something for you. If not, they should be able to point you to the right direction or customize their own kits to suit your needs
