Oct 22, 2009, 05:34 PM
Personal Sales Rating: ( 0)
2009 Mitsubishi Lancer
Drives: 09 white lancer gts stock =(
Id suggest calling the dealer and asking them but thats what my instructor told me, he didnt specify if it was all cvt trannies but im pretty sure it is.
Offline
Oct 23, 2009, 05:41 AM
What kind of internals are you putting in your tranny? i never heard of upgraded internals on a cvt
Offline
Oct 23, 2009, 02:26 PM
Drives: 2009 Lancer GTS
haha well the reason you've never heard of it is because i believe i will be the first to do it in a lancer cvt maybe dont quote me. Im going to make some upgraded parts and internals to give the cvt more strength to be able to handle a turbo application.
__________________
[x]Greddy TI-C
[x]Fujita SRI
[x]Greddy Emanage Ultimate
[x]Kenwood Custom System
[x]Eibach Sportline Springs
[]Megan Racing Seats
[]Megan Racing Coilovers
[]Enkei RPF1
[]5% tint
[/]Turbo Install (wip)
Offline
Oct 24, 2009, 07:14 PM
nice that takes some balls man i give you props. How much experience do you have with doing these things?
Offline
Oct 29, 2009, 07:56 PM
Drives: 2009 Mitsubishi Lancer GTS
Hi new guy here.
Thats great that pistons and rods are the same but does the header/manifold have the same bolt pattern? Im looking to make my own kit as well and didnt want to spend more time without my car by having parts fabricated.
Offline
Oct 29, 2009, 08:17 PM
well i worked/studied all last year at RIT (mechanical engineering major) with fabrication/design/engineering, and used CNC machines and mills. I did a fair amount of CAD and hands on experience with metal working and milling, materials testing and materials technology. So im fairly new in experience but highly educated about it, so i have more knowledge then the average do it yourself in your garage person, but maybe not as much as say ams or a bigger company like that.
__________________
[x]Greddy TI-C
[x]Fujita SRI
[]Enkei RPF1
[]5% tint
Offline
Oct 29, 2009, 08:28 PM
Personal Sales Rating: ( 13)
Drives: RWD EVO & 09 Lancer GTS
Quote:
Originally Posted by BladeZero
Hi new guy here.
from what I have compared between both the C-SRT4 and Lancer service manuals the heads are the same.
Offline
Oct 30, 2009, 07:38 AM
Drives: Lancer DE, DAKOTA R/T
ok here is also what you need to find out. the bore and stroke may be the same and infact it is but the pison head is the thing. is it taller or shorter then the lancers pistons. if its taller you can break a rod bend a valve lots of variables. my dad said to call hyndai they are how made the designs for the caliber and the 2.4 in said car in conjuntion with chrysler and mitsu. but i still wanna know why a caliber r/t can make 178hp and the 09 GTS only has 168hp?
Offline
Oct 30, 2009, 07:46 AM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
Quote:
the dodge caliber r/t is rated at 172HP and 165 lb*ft of torque. where we have 168 hp and 167 lb*ft of torque.
"The R/T model has a 172 hp (128 kW) 2.4 L version of the GEMA engine"
http://en.wikipedia.org/wiki/Dodge_Caliber
http://autos.aol.com/cars-Dodge-Cali...hback/overview
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Oct 31, 2009, 08:46 PM
Drives: 09 Lancer GTS
according to automotive.com we have the same bore and stroke as a 2010 dodge caliber srt4. this only goes for the 4b12 guys.
the application of srt4 internals will be awesome for turbo but not so much for N/A
srt4 compression ratio is 8.6
Offline
Oct 31, 2009, 10:41 PM
Drives: 09 lancer GTS
it would be nice if some on can confirm that the c-srt4 and 4b12 pistons and rods can be swapped..........
Offline
Nov 2, 2009, 06:37 PM
What about the ECU the ECU should be same right?
__________________
Vehical
Technicality
Engine's
Crap
VTEC: All the turbo lag with none of the boost
Offline
Nov 2, 2009, 07:51 PM
no the c-srt4 ecu will be different in the sense its tuned for boost
Offline
Nov 2, 2009, 08:05 PM
Personal Sales Rating: ( 3)
Drives: 03 evo
Idk about swapping the internals over from a csrt4 to a lancer. But I know that the csrt4 motors are really strong I own a 08 csrt4 and I put down 440whp without any problems and as far as the motor going past 400whp people are blowing headgasket and blowing motors so from what I read if you do head studs and gasket you should be good to go. I know there's two shops making well over 500whp on the stock long block with arp headstud and gasket. If you plan on turboing your lancer and you can swap the internals I think that will be a great upgrade.
__________________
drive: 91 galant vr4 and 08 caliber srt4
Offline
Nov 2, 2009, 08:23 PM
Quote:
I know but Im looking to make my own kit so I am trying to solve the problem of engine management
__________________
Vehical
Technicality
Engine's
Crap
Offline
Tags
04, 4b12, arp, bolt, csrt, ecu, engine, head, internals, replacement, spec, specs, srt, srt4, studs, torque, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
