Sep 22, 2009, 12:03 PM
Personal Sales Rating: ( 2)
2003 Mitsubishi Lancer
Drives: 2003 Lancer esturbo
List of Turboed Lancers
Ok so i figured we should start a list of everyone on here that has a turboed lancer.
Maybe we could separate it by custom install - 16g
other turbo
rrm kit
This way we get to know whose got what and if we ever need to ask any questions then the list is right here.
Once ur name is on the list, and u send me a dyno sheet, ill update with ur HP and torqe.
and have a link to ur build thread if u have one
16g custom install:
zulu989 ---------- 182 whp / 190 trq 7 psi
Link62 ---------- coming soon
JRR ------------ 11 psi
Boostedlancer$ ---------- 313hp / 326 trq 19 psi
ThunderOZ --------- ?
sawulkn ---------- ?
03lances ---------- coming soon
lancerEVA06 --------- ? 9 psi
Incrphish ------------?
lilazn64 -------------- ?
oz rally ------------- 10 psi
RRM:
4g94T ---------------------216 hp / 278 trq 14 psi
lancerguy'03 -------------185 hp / 210 trq 7 psi
t3lancer2003 ------------- ?
Green_bandit ------------ t 28
Custom:
depsy ----------------235 whp / 233 trq (aem ems tuned also @ 10psi)
cincy --------------------- gt28r 190-200 whp 7 psi
Demon ni2 ------------- garrett 60 trim t3/to4e 197 hp / 180trq 5 psi
puerto reCOn
brutus.nova
blah blah blah so send ur infooooo
__________________
.:. 03 Lancer ES TURBO.:.
.:. AIT RACING FF2 BODY KIT .:.
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. Electric Blue Perl .:.
.:. stage 3 fx300 .:.
.:. Full 3 inch magnaflow.:.
.:. Greddy Rs .:. rrrRRRR(PSHhhh)rrrRRr
.:. fully built .:.
Offline
Sep 22, 2009, 01:14 PM
Personal Sales Rating: ( 0)
Drives: audi TT
I was running a
RPW manifold
RPW DP
gt28r @ 7psi
custom fmic and tune
stock injectors and engine
walbro intank
No dyno, but deff between 190-200whp
__________________
stroked and tons of boost
Offline
Sep 22, 2009, 04:09 PM
Personal Sales Rating: ( 13)
Drives: 03 16g lancer es
i got 16g
tre 255 pump
wrx 440cc
megan mani with 93 flange
everyting else evo
will have dyno soon
Offline
Sep 22, 2009, 05:00 PM
Personal Sales Rating: ( 5)
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
josh here-
evo 3 big 16g
wrx440's
501 maf
rrm mani (due to the turbo)
basically all evo from there
evoscan and ecuflash tune
rrm full ported intake side (im, tb, and rail)
Offline
Sep 22, 2009, 05:05 PM
Drives: The lution
I have an evo engine that will be done for next season.
__________________
3rd KREW Performance
Offline
Sep 22, 2009, 08:05 PM
Drives: 2002 Turbo Lancer 19lbs of Boost
I have a 02 lancer with a custom evo 9 16g on it fully built top to bottom. right now on 19lbs of boost i made 313hp and 326 ftlbs of torque. the reason i didnt make more power is that i didnt know that i had to degree my new 272 intake and exhaust cam with adjustable gear. once i degree that and adjust the timing i should be in the high 300's but thats all for this season it almost winter here.
Offline
Sep 22, 2009, 08:30 PM
Personal Sales Rating: ( 1)
Drives: 2003 Lancer OZ Rally [ Lightning Yellow ]
sawulkn
, a local sclc member is turboed aswell doont know what else he has besides the evo 16g + related turbo stuff..hes being deployed to iraq so dont know anything else except what i seen inperson
Offline
Sep 22, 2009, 08:52 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Murphy(sawulkn) is running close to the same setup as me:
Evo 8 16g, evo piping, 12:1 fmu, megan mani with 4g94 flanged welded to it, megan o2, walbro 255.
I'm also running 8psi, using an evo 9 bov, hks intake and will soon add wrx 440cc injectors
Reason: Added information.
Offline
Sep 22, 2009, 09:05 PM
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Not turboed yet but by the end of next month ITS ON!!!!!! most of my parts are in my sig.
__________________
16G Turbo build: Build completed tuning time
Offline
Sep 22, 2009, 09:10 PM
Drives: 06 EVAlution IX; 93 EVO I; 06 ES (DD)
TDO5-16G, E85, Evo 8 ECU, 550cc injectors, walbro 255 (still on returnless fuel system). No clue on horse power numbers, but running 9psi boost, and 10:1 AFRs (tuned strictly for E85)
__________________
XBL Gamertag: LancerEVA06
Quote:
Originally Posted by LancerEVA06
Me: looks like a shopping cart with that wing.
Him: o jeez
Me: We have Shopping Carts for balls
Me: HAHAHAHAHAHAHAa;sdf
Me: I mean cars
Him: u smoke something there dude? lmao
Offline
Sep 23, 2009, 12:16 PM
Drives: 02 lancer es turbo
16g basic same set up as thunderoz
Offline
Sep 23, 2009, 02:00 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
everyone should be posting what kind of dyno and the correction factor, otherwise comparing these numbers is useless.
Im surprised no one is using Virtual Dyno Room!
Offline
Sep 23, 2009, 02:46 PM
we not rele comparing,we just making a list. and what is virtual dyno room, i havnt heard of it
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Sep 23, 2009, 03:08 PM
im trying to get pocket dyno on my ipod to work annd get some rough numbers. unfortunatley no time aor money to actually got and get it dynoed.
o and an fyi im at 11psi as of now with the greddy profec b spec 2 boost controller
josh
Offline
Sep 23, 2009, 03:15 PM
This is Virtual Dyno Room.
There is an evoM correction factor that everyone on evoM uses to compare numbers.
Those that use mitsulogger or evoscan can copy / paste their logs onto this excel spread sheet. Just input the weight, gear ratio, occupant weight, and tire size.
Offline
Tags
440cc, custom, dyno, es, hp, injectors, krew, lancer, lancers, rating, sheet  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
