Sep 9, 2009, 07:45 PM
Personal Sales Rating: ( 5)
2003 Mitsubishi Lancer
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
o2 housing
im lookin to change a few things up. mainly 02 housing and dp. i have the evo 3 big 16g with tthe 7cm turbo inlet flange on it (older eclipse style inlet).
does anyone know if like a megan o2 housing for an evo 8 turbo will fit? i know there are slight differences between 16g turbos, but was just wondering if it will fit.
also if you could post turbo, o2 housing, and dp that you are using it would be appreciated.
thanks
josh
Offline
Sep 9, 2009, 08:32 PM
Personal Sales Rating: ( 12)
Drives: a boostmobile
In a couple of days I'll be running:
- 16g6 with ported 10.5 hs.
- ported stock o2 housing
- 3" devo tuning downpipe
My manifold, hotside, and o2 are also ceramic coated.
Offline
Sep 9, 2009, 11:46 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
Nice were did you send the manifold and o2 to have them coated? And about how much did it cost? And to answer the question i also will be when my kit goes on using a 16g6 with stock o2 dump but a megan 3'' DP.
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Sep 10, 2009, 12:00 AM
Quote:
thats the evo style turbo i take it?
just wondering for my sake and in possible future build.
Offline
Sep 10, 2009, 07:14 AM
The 16g6 is off the evo 8. And i think the 10.5 hotside is off the evo 9.
__________________
Needs injectors
Offline
Sep 10, 2009, 08:03 PM
I coated them myself, very easy process.
2005 Evo 8 also has a 10.5 hs. That's the one I gots.
Offline
Sep 10, 2009, 10:32 PM
Personal Sales Rating: ( 13)
Drives: Evil 8
The evo 8 o2 housing will not fit the evo 3 turbo. The evo 3 turbo is alot smaller and faces the opposite direction. Down pipe wont fit either. Do you have this turbo installed? If so, can you post a pic of it?
Reason: 3 not 4
Online
Sep 10, 2009, 11:01 PM
Quote:
Originally Posted by Chele
The evo 8 o2 housing will not fit the evo 4 turbo. The evo 3 turbo is alot smaller and faces the opposite direction. Down pipe wont fit either. Do you have this turbo installed? If so, can you post a pic of it?
i will post i big pic of it tmw when i can get out there with my camera.
josh
Offline
Sep 11, 2009, 07:26 AM
Not trying to steal the thread but where did you get the coating from? and about how much was it?
__________________
Needs injectors
Offline
Sep 13, 2009, 12:48 PM
ok so i havent really been able to find an answer to my main question....
will the evo 8/9 o2 hpusing boult up to my evo3 big 16g?
i contactyed rob at road race but with no response back yet.
Offline
Sep 13, 2009, 01:07 PM
ok so here are some pics i just took. this is the rrm 02 housing that they sell.
and attached are some of it installed.
josh
Offline
Sep 14, 2009, 01:05 PM
ok so after some fffffffuuuuuuuuuuuuuuuuurrrrrrrrrrrrrrrrrrtttttttt ttttthhhhhhhhhhhhhhheeeeeeeeeeeerrrrrrrrrrrrrrr research the flanges are different. dang it! just have to make my own then!
Offline
Sep 14, 2009, 07:01 PM
Drives: Evil 8
I answered your question.
Online
Sep 14, 2009, 07:08 PM
ya sorry bout that. i was determined that it would work. my bad.
i was more concerned with the bolt pattern on the hotside. my turbo goes the same way as the evo does, just a little different design on the turbo though.
Offline
Sep 14, 2009, 07:13 PM
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
You coated the pieces yourself? Any reviews on how it will hold up? Was it rather easy? Setup looks good, congrats.
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Tags
02, 2003, dp, evo, evo3, flange, flanges, housing, megan, o2, racing, review, reviews  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
