Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 4, 2009, 07:01 PM   #1
Personal Sales Rating: (1)
darkmitsu's Avatar
Drives: 02 mitsubishi lancer es
what radiator fans do you run after you turbo?
As the title states, when you have limited room after swapping your manifold and putting a turbo in there, what do you do for cooling? What radiator do you run , what fans do you run?
__________________
2002 mitsubishi lancer ES
[x] Lancer evolution 8 ECU 94170015.bin
[x] Mitsubishi Eclipse 501 MAF
[x] K5M422F6ND w/ Lancer differential
[x] 4g64
[x] exedy clutch kit
Offline
Old Sep 4, 2009, 09:25 PM   #2
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
I used to run a custom modified aluminum half size radiator for a Civic with a Flex-a-Lite slim 12" puller on my original 16G6 kit. After I switched to my ram horn manifold more room was freed up so I eventually switched to a CBRD full size Evo radiator. I run two 10" pusher fans in front of the condenser now and they work beautifully.
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Old Sep 4, 2009, 09:33 PM   #3
Personal Sales Rating: (13)
03lances's Avatar
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Well I havent put my turbo kit in yet but I have a 10" push/pull slim fan capable of 1550 cfm that will be going in with the kit
__________________
16G Turbo build:
Build completed tuning time
Offline
Old Sep 4, 2009, 09:53 PM   #4
darkmitsu's Avatar
senate do you have a picture of your fan setup , also are you using the original fan controller box looking thing that is mounted on the fan closest to the driver side?
__________________
[x] 4g64
Offline
Old Sep 4, 2009, 10:09 PM   #5
Personal Sales Rating: (21)
ThunderOZ's Avatar
Drives: 02 Lancer OZ 16G TURBO
Send a message via AIM to ThunderOZ Send a message via Yahoo to ThunderOZ
I'm using one 10" push fan I bought off of ebay... I haven't had any overheating issues, even on days that hovered around 100 degrees. I also have a vented hood.
__________________
-Merc
Build thread on Mitsu-Media
Cardomain
Offline
Old Sep 4, 2009, 10:26 PM   #6
link62's Avatar
Drives: 03 16g lancer es
Send a message via AIM to link62 Send a message via Yahoo to link62
thunder or any one that has the push/pull fans can take a pic of how ur blades are on ur fans cause i got the push/pull one off ebay and i powered it to see if i can get it to push the in to the car but it seems to be pushing air toward the front of the car if mounted on the front and when i flip the blades it sucks air still pushed out the front but not as much
Offline
Old Sep 4, 2009, 11:00 PM   #7
ThunderOZ's Avatar
You know what, now that I think about it, I'm not sure if it's on right or not... Was I supposed to reverse the fan blades as well as the polarity?
__________________
-Merc
Cardomain
Offline
Old Sep 4, 2009, 11:11 PM   #8
03lances's Avatar
You dont reverse the blades on the fan you just reverse the wires on a push pull. If it is pulling air then reversing the wires will push the air
__________________
16G Turbo build:
Offline
Old Sep 4, 2009, 11:14 PM   #9
link62's Avatar
ok that what i was thinking but i wasnt sure since one is black and one is blue so i figured blue is positive and black is negative but ima go try it the opposite right now let u know what happens
Offline
Old Sep 4, 2009, 11:21 PM   #10
link62's Avatar
k update i went and reversed the wireing and it did a push it the other way but didnt put out enough air cause of the blades facing the opposite way so fliped the blades and did it again and a lot more air was flowing so now its good to go thanks
Offline
Old Sep 5, 2009, 12:05 AM   #11
ThunderOZ's Avatar
just curious, when on the car do the blades spin clock wise or counter clockwise (when looking through the screen of the fan grill)?
__________________
-Merc
Cardomain
Offline
Old Sep 5, 2009, 12:08 AM   #12
link62's Avatar
i havent put mine on the car but they would spin clockwise
Offline
Old Sep 5, 2009, 12:10 AM   #13
ThunderOZ's Avatar
So you just flipped the blades? How hard was that to do?
__________________
-Merc
Cardomain
Offline
Old Sep 5, 2009, 12:11 AM   #14
link62's Avatar
not hard at all just took the nut off and fliped put the washer on the other side tightend\
and yea just fliped the blade and polarity, blue negative and black positive.
Offline
Old Sep 5, 2009, 12:15 AM   #15
ThunderOZ's Avatar
How is yours mounted?
__________________
-Merc
Cardomain
Offline
Tags
2002, clock, eclipse, evo, fan, half, issues, k5m422f6nd, lancer, mitsubishi, overheating, oz, proper, radiator, slim, wise
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
