Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 31, 2009, 09:29 AM   #1
Personal Sales Rating: (3)
Drives: Lancer 2008 ES
Help creating my turbo kit
I recently bought a used evo X turbo andam thiking bout putting it in my car.
A problem I'm havng is tha the wastegate is set to open at 11 PSI. From what I understan this means that the pressure will never go under 11 PSI even if I use a boost controller.
-I've thought about buying the ATP O2+Downpipe where you can hook up a Tial external wastegate and block off the internal one.
-Another solution I think would be to adjust the wastegate actuator to a lower presure, but I'm not sure that will work.
What I want is to run the turbo at low boost (3 PSI) and then up the boost when I get a tune. Anyone know what I can do?
__________________
Drivetrain:
[X] RRM SRI
[X] RRM Pulley
[X] RRM Headers
[X] Greddy Ti-C Exhaust
[X] Works short throw shifter
[X] Works shift knob
Suspension:
[X] Progress Springs
[X] Progress Swaybar
[X] RRM Front Strut Bar
Show:
[X] Tints
[X] 10 in Pionneer Subwoofer
[X] 2008 GTS side sills, front air dam and scuff plates
[X] 18 in Enkei Wheels
[X] 8000K HID's
[X] Painted interior parts white
[X] RRM rear lip spoiler
Online
Old Aug 31, 2009, 06:07 PM   #2
Personal Sales Rating: (0)
Drives: 09 Lancer GTS
You will need to change the spring in the wastegate to run a lower PSI.
Offline
Old Aug 31, 2009, 06:14 PM   #3
Ok, but I'm not sure I can change the spring in the internal wastegate.
I could get an external one but its going to be a lot more expensive.
__________________
Drivetrain:
[X] RRM SRI
[X] RRM Pulley
[X] RRM Headers
Suspension:
Show:
[X] Tints
[X] 8000K HID's
Online
Old Aug 31, 2009, 06:26 PM   #4
Unfortunately I don't know about changing out a spring in an internal wastegate, but I will search around to see if I can find something.
As for the external one it would be more expensive since you would have to not only get the external wastegate but a manifold that supports an external wastegate.
Edit:
There is the actuating rod on the internal wastegate that can be adjusted, but if you don't know what you are doing I wouldn't advise this. I would take it to someone who has done it before.
Offline
Old Aug 31, 2009, 09:21 PM   #5
Personal Sales Rating: (6)
2008 Mitsubishi Lancer
yitzac1990's Avatar
Drives: Boosted 2008 Mitsubishi Lancer
Send a message via AIM to yitzac1990 Send a message via MSN to yitzac1990
IF the stock internal wastegate actuator rod IS adjustable, you can do it that way, but it might also let the wastegate itself be slightly open most of the time due to the lower pressure.
and ill be in melbourne this weekend if you want to meet up man!
__________________
2008 Lancer GTS 5-speed
FIRST XtremeBoost turboed Lancer, tuned by Jestr
240 whp
228 wtq
...on a mustang dyno
HAD the world's fastest 2008 Lancer
http://www.cardomain.com/ride/3070504
Offline
Old Aug 31, 2009, 10:09 PM   #6
Thanks for the help guys. Actually I'm thinkin of the evo x manifold which will fit since I purchased a head flange from the evo x and it matches perfectly to my stock header. As for the external wastegate I'm thinkin about this:
http://www.atpturbo.com/Merchant2/gr...-023_450-2.jpg
Which will cost around 800 bucks total which im not lookin forward to.
Awsome cory. Sorry I haven't called, I just got back to the U.S a while ago, I was on vacation. I' ll give u a call on the weekend see if we meet.
__________________
Drivetrain:
[X] RRM SRI
[X] RRM Pulley
[X] RRM Headers
Suspension:
Show:
[X] Tints
[X] 8000K HID's
Online
Old Sep 1, 2009, 08:50 AM   #7
yitzac1990's Avatar
alright cool, lookin forward to it
idk about that wastegate setup, the wastegate must come before the turbo, not after it, thats why it always comes off the headers. i say (if you can) modify the stock header you are getting to accomodate an external wastegate. i.e. drill a big hole in the header near the flange (where all the pipes meet) and weld some pipe in to go to the wastegate.
__________________
240 whp
228 wtq
Offline
Tags
change, internal, spring, wastegate
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
