May 4, 2009, 07:09 PM
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
Narrowband A/F help needed.
I bought a sunpro narrowband gauge the other day. BUT it's giving me problems. If I hook it up it will NOT sweep. I do not know why? I pulled up a diagram and it said it was the white wire so I tried that. But of course I didn’t work then I tried the other 3 still will not sweep? WTF  anyway I got a new gauge thinking it was bad yet again still the same thing. And the o2 is brand new also I stuck the gauge on my friend turbo Eclipse and it worked just fine? If anyone has any idea's please let me know. As I am lost
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
May 4, 2009, 09:01 PM
Personal Sales Rating: ( 0)
Drives: audi TT
whats the point of this? A narrowband o2 is worthless. You just wasted money and now time trying to install it. If you want to monitor your engine, get a wideband and get real a/f numbers
hell, you could of just got a apexi TT and taped into the stock reading and got the same bad readings
__________________
stroked and tons of boost
Offline
May 5, 2009, 02:22 AM
The point of the narrow band was as a secondary safty. Since it is my dd it will let me know if the o2 is going bad. also if the wideband would go. Im not dumb im not going to use it to tune. Plus is not like it was a lot maybe 20$.
__________________
Needs injectors
Offline
May 5, 2009, 02:49 AM
Personal Sales Rating: ( 16)
Drives: EVO VIII RS
A narrow band 02 gauge is like a Fire place simulator. Sure it might look cool, but ummm, its doing nothing.
$20 wasted either way you look at it.
__________________
__________________________________________________
--------------- Tuned by "ONRAILS" ---------------
__________________________________________________ _
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
