Nov 4, 2009, 01:44 AM
#391
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Quote:
Originally Posted by steven121
It looks really good comgrats man, for your 440cc injectors did you you have to purchase a new manifold to fit those, or will the stock fuel rail work with 440cc injectors? and do I need to do any modifications to the fuel rail in order to make the fuel flow properly through the injectors, like making the holes on the end bigger?
As long as they are 440s out of a early 2000s wrx no mods are needed they are quite literally just drop in  although you will need some way of controlling them which is where ecuflash comes in
__________________
16G Turbo build: Build completed tuning time
Offline
Nov 4, 2009, 06:09 AM
#392
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Don't forget about a larger fuel pump too.
Offline
Nov 5, 2009, 01:55 AM
#393
Ok so progress report, today got off work at 7, stopped and got some vaccuum line and the o rings for the injectors, and managed to port the intake manifold, pull the transmission which BTW the drivers side half shaft is a PITA to get out of the tranny so I pulled the tranny then removed it which I could do since I brought it out through the top  much easier. I stripped the manifold bare and brought it over to my parts washer and went to town scrubbing the crap out of the inside, I didnt want ANY metal shavings going through my engine. After that I rinsed it out and reinstalled everything with my new 440s  which BTW do not need longer bolts as I read somewhere on here, they dropped right it, also it really helps to put a very thin layer of multi purpose grease on the o rings and they slide right in.
__________________
Offline
Nov 5, 2009, 10:30 AM
#394
Personal Sales Rating: ( 0)
Drives: 2002 Lancer ES
[quote=03lances;7682365]As long as they are 440s out of a early 2000s wrx no mods are needed they are quite literally just drop in  although you will need some way of controlling them which is where ecuflash comes in[/quote
what year of wrx would you prefer to get the fuel injectors at?
also thunderoz said don't forget a bigger fuel pump does he mean the 255 walbro fuel pump or a diffrent type of fuel pump? if he meant the walbro I have that on my list
Offline
Nov 5, 2009, 11:02 AM
#395
Yea I meant either 190 or 255... I got my injectors from an 04...
Offline
Nov 5, 2009, 01:22 PM
#396
Yup I have a walbro 255 and my injectors came out of an 03
__________________
Offline
Nov 6, 2009, 03:42 AM
#397
Ok just got done tapping the oil pan for the return line. Turned out beautifully although I almost tapped it too big but it sits firm all the way in so we are good  Tomorrow morning I want to run the wires through the firewall for the gauges before putting the engine and trans back in. Got a couple buddies coming over gonna have them start pulling the fuel pump and front bumper off. Since I have to let the silicone cure for 24 hours on the oil pan I wont be able to fire it up until Saturday but no big.
__________________
Offline
Nov 6, 2009, 09:47 AM
#398
Quote:
Sweet thanks man can't wait to turbo my car.
Hey do you think a 02 lancer es can be a infiniti G37?
if I run about 250-275 HP I think I would kill that car? don't worry his is stock we got a $1000 bet going on.
I already ran the statisics at 250 hp is should be a close race on the drag strip?
Offline
Nov 6, 2009, 10:34 AM
#399
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS
sigh.....
you will not hit 250-275whp unless you plan on replacing engine internals, and then you're gonna have to work with the drivetrain too to put that power down to the pavement.
You're looking at 225max on stock internals.
__________________
2009 Lancer GTS 2.4L Octane Blue
No Mods yet, but some coming soon i'm sure :)
Previous car - 2003 Lancer OZ, boosted with custom turbo kit at 7psi.
Offline
Nov 6, 2009, 01:51 PM
#400
Quote:
Originally Posted by Sicktght311
sigh.....
yeah i knew that I should have put that there, but I plan on running 250 with pistons and rods. aand then 275 with a port polish also. but I won't go any higher than that. That would probably beat a majority of cars anyways.
this one guy did a complete rebuild on his engine he is pushing 339 WHP he spent nearly $27,000 on it. If you want to see what he has go to speedcorps.com and click random stuff, its a pretty sweet ride.
Offline
Nov 6, 2009, 03:14 PM
#401
 You do realize that Robert is a member here and the $27,000 was on the entire car, cosmetics, custom paint, etc, not just motor right?
Offline
Nov 6, 2009, 06:23 PM
#402
Alright guys another update so this is the first day I havent had to work so I have gotten alot done. Fuel pump is done, FMIC is mounted, clutch is in, engine and trans are back in the car, and more I will keep updating you
__________________
Offline
Nov 6, 2009, 06:35 PM
#403
2003 Mitsubishi Lancer
Drives: 2003 Lancer esturbo
i have a completely built motor, too bad its sitting in the garage waiting for the cam rest of the final touches lol
__________________
.:. 03 Lancer ES TURBO.:.
.:. AIT RACING FF2 BODY KIT .:.
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. Electric Blue Perl .:.
.:. stage 3 fx300 .:.
.:. Full 3 inch magnaflow.:.
.:. Greddy Rs .:. rrrRRRR(PSHhhh)rrrRRr
.:. fully built .:.
Offline
Nov 6, 2009, 09:23 PM
#404
Quote:
No actually I didn't I just thought it was on his engine or something? I forgot about the cosmetics, well thats cool he is a member!
Offline
Nov 6, 2009, 09:24 PM
#405
Quote:
Dude that sucks man, thats like when I was trying to install my short shifter at night, it sucks to wait another day lol
Offline
Tags
16g, 4g63, 4g94, 4g94t, big, domolution, es, evo, flange, installing, lancer, lancershop, manifold, put, refurbished, rims, river, toms  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
