Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 25, 2009, 05:02 AM   #1
Personal Sales Rating: (2)
Lucas03ES's Avatar
Drives: 2003 Rio Red Lancer ES
Send a message via AIM to Lucas03ES Send a message via MSN to Lucas03ES Send a message via Yahoo to Lucas03ES
16g oil feed / return & other questions
Would it be better to use this than a stock oil feed line?
http://cgi.ebay.com/ebaymotors/14B-1...Q5fAccessories
What about this for the return line, since my turbo was missing the stock one when I received it?
If that would work, how would I fit it up properly to a ss line so it would not leak?
thanks
Offline
Old Apr 28, 2009, 11:15 PM   #2
Lucas03ES's Avatar
Also, what about the stock evo intercooler piping, what would I need to do to get it to fit on an auto tranny besides relocate the battery and move the coolant resovoir?
Offline
Old Apr 29, 2009, 12:15 PM   #3
Personal Sales Rating: (13)
2002 Mitsubishi Lancer
Green_Bandit's Avatar
Drives: A b00st3d 2002 Lancer OZ
Send a message via AIM to Green_Bandit
Thats just about it. If youre running manifold to turbo you'll be good to go. If you happened to run RRM's kit with the J-pipe you'd have to lose that wind shield washer bottle. Bt other than that things fall into place nicely. You might even be able to sqeeze by with a mini battery.
__________________
Check out my for sale thread! Boost gauges and accessories
4G93 ported powder coated Intake Manifold for sale
Short turbo mod list!!!
[x] Magna Catback
[x] RRM Pully
[x] Enkie J10's with Yokohama Parada Spec 2's
[x] RRM Piggyback
[x] RRM X bar strut bar
[_] RRM rear strut bar
[_] Slotted Rotors and pads
[_]TEIN S-Tech Springs
MyCar
Join Tunerfriends!
RRM Header install/Review
Offline
Old Apr 30, 2009, 12:12 AM   #4
Lucas03ES's Avatar
Well I already have rather large power wire ran to the trunk so it would be easier to just do that.
What would be a good idea to upgrade with the piping while I have it? Like couplers, clamps etc.?
Offline
Old May 2, 2009, 11:17 PM   #5
2003 Mitsubishi Lancer
Drives: 2003 Mitsubishi Lancer OZ Rally Edition
I would buy the oil feed line kit for the 16g turbo from RoadRaceMotorsports and would buy a oil filter sandwich adapter from GlowShift Gauges that Way you dont have to tap your oil pan
Offline
Old May 3, 2009, 03:43 PM   #6
^^^Whoa! What?! No, that wouldnt work. The oil return is gravity fed, thats why you have to tap the pan in a specific place. (Not too low on the black part). The spot where an oil sandwich adapter would go is a crazy and risky spot to be returning oil. The line would have to as near straight as possible with no sags or droops (since oil is falling into it and not "pushed").
Tap the pan bro. I have the taps and drill bit for sale if you need it. Its not hard, I promise!
__________________
[x] Magna Catback
[x] RRM Pully
[x] RRM Piggyback
MyCar
Join Tunerfriends!
Offline
Old May 3, 2009, 07:39 PM   #7
Personal Sales Rating: (7)
Demon_ni2's Avatar
Drives: BIG Turbo OZ
Send a message via AIM to Demon_ni2
drill and tap.. or get a good aluminum fitting to weld in..(mine is welded it)
all u need is the feed line and the fitting for the retrun line.. the braided hose for the feed line and also a high temp silicon or rubber hose for the return line.. all will work just fine.. no point in buying a kit to do it.. all u need is the fittings.. rest u can get locally for cheaper..
__________________
EPM built - Custom 60 Trim t3 Turbo Lancer - Built by Q@evopowermods - tuned by TouringBubble
13.4@109street tires 12.8@111 on 22x8 slicks..
click here ---> MY TURBO KIT IS FOR SALE!!!! <--- click here
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
