Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 5, 2009, 03:19 PM   #1
Personal Sales Rating: (12)
OZ Rally's Avatar
Drives: a boostmobile
Send a message via AIM to OZ Rally
Turbo Problems
So I finished installing all the parts to my Turbo Kit and when I go an fire it up it revs all the way up and then shuts off. I try it again and does the same thing, but when I give it gas it just sputters and then dies. It seems like a vacuum leak or something since it can't keep an idle. I also just tried to throw on the SRI to see if it would work n/a and it does the same thing! WTF!?!?!
Mods:
t-25 Nissan Turbo
tubular mani
turbosmart wg with 7psi spring
custom downpipe with stock exhaust
metal evo IX bov
maf sits a little low but is facing straight
evo icp and intercooler
walbro 255
fmu
stock injectors (also have 460cc rx7 injectors but don't want it to be too rich)
ngk iridium IX
ported 4g93 IM
I desperately need some help since I've been at it since Wednesday. I was thinking it could be that I need a tune. idk
__________________
::CHI-BURBS MITSU::
Quote:
Originally Posted by Nubby View Post
If a good forum is like a good college party, then EvoM is at the point when the high school kids showed, drank all the beer, barfed on everything and now the keg is empty and there's no money for another one.
FS: Megan Manifold & Stock Parts
FS: Stock/Aftermarket Parts and Random Mitsu Merch
FS: Meth Kit
FS: All Stock Speakers
Offline
Old Apr 5, 2009, 03:43 PM   #2
Personal Sales Rating: (14)
Drives: '03 Evo brain'd Lancer OZ-T
What kind of vacuum readings are you seeing at idle? What are your AFRs at idle? A vacuum leak or stuck open BOV might be the culprit.
Offline
Old Apr 5, 2009, 03:47 PM   #3
OZ Rally's Avatar
Ummm... that's the thing, no gauges. I kind of hurried into installing this and now I'm paying the consequences.
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 07:10 PM   #4
OZ Rally's Avatar
help me out plz.
pics of the setup.
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 07:11 PM   #5
OZ Rally's Avatar
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 07:12 PM   #6
OZ Rally's Avatar
I also took out the uicp and put the SRI and it wouldn't work.
Video of the startup...
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 07:19 PM   #7
Personal Sales Rating: (3)
1997 Mitsubishi Eclipse
Drives: 1997 Eclipse GSX
Fuel or air. Did you check for "boost leaks". Which fmu do you have? Are you sure you have enough fuel pressure?
__________________
DSM>EVO
Offline
Old Apr 5, 2009, 07:27 PM   #8
OZ Rally's Avatar
I'm not sure about the fuel pressure, i have no gauges yet.
I do have a walbro 255, vortech 12:1 fmu. How would I check for boost leaks with the car off?
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 07:29 PM   #9
+1
Double-check for boost leaks at every coupler and connection.
Offline
Old Apr 5, 2009, 07:35 PM   #10
OZ Rally's Avatar
But since I put it back to n/a (SRI) wouldn't it run with no problem?
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 07:47 PM   #11
OZ Rally's Avatar
Bump...
I need help guys.
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 08:06 PM   #12
KillahB's Avatar
Drives: 04 4G69 (daily) 97 Mirage 4G63 powered (fun)
Send a message via AIM to KillahB Send a message via Yahoo to KillahB
Could be as simple as you're out of gas, but assuming that is out of the question, it sounds fuel related. Can you hear the Wally whine? What about your fuel filter? Can you rev the car at all or keep it running until idle? Or even with gas, it dies?
I would even suggest checking the ISC motor since it isnt idling. I doubt this is the problem tho because the car just isnt running.
__________________
Daily driver: 4G69 powered Ralliart Lancer
Fun car: 4G63 powered 5th Gen Mirage
Offline
Old Apr 5, 2009, 08:19 PM   #13
OZ Rally's Avatar
Yea I would have to press the pedal to keep it running, when I touch it the revs spike up then drop instantly. It has half a tank of 91 and I can't really here the walbro run since I'm trying to here for knocking. I disconnected the fmu and tried without it and that didn't work.
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Old Apr 5, 2009, 08:46 PM   #14
Personal Sales Rating: (7)
Demon_ni2's Avatar
Drives: BIG Turbo OZ
Send a message via AIM to Demon_ni2
um.. what is it rev'in up to while its trying to idle.. could be a fuel or ignition issue (mine sounded like ass untill we dialed the injectors in a little)
double check all your fluids and all your plugs/wire connections also, (your plugs need to be gapped to .030, if u have those NGK turbo spark plugs that are .044 plugs u need to regap them or use your stock plugs)
idling issues could be any (air/fuel or ignition) (check the gapping in all the plugs, that might be the issue)
__________________
EPM built - Custom 60 Trim t3 Turbo Lancer - Built by Q@evopowermods - tuned by TouringBubble
13.4@109street tires 12.8@111 on 22x8 slicks..
click here ---> MY TURBO KIT IS FOR SALE!!!! <--- click here
Offline
Old Apr 5, 2009, 08:50 PM   #15
OZ Rally's Avatar
I just bought the NGK Iridium IX plugs today and gapped them at .030.
I have a feeling it just needs to be tuned. Right when I turn it on it revs to 3500 or so and just drops and turns off.
__________________
::CHI-BURBS MITSU::
FS: Meth Kit
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
