Mar 30, 2009, 01:54 AM
Personal Sales Rating: ( 0)
Drives: 2005 lancer es
boost question on 05 lancer es
how much boost can stock injectors and fuel pump handle?
from what ive read 4-5psi is usually fine.
Offline
Mar 30, 2009, 08:18 AM
Personal Sales Rating: ( 7)
Drives: BIG Turbo OZ
if your not going to upgrade the car properly dont do it at all. please stop making threads asking the same things over and over. your talking a difference of about 200$ on a build.. there the easiest things to install on a turbo build.
if it takes you a whole year to get the parts to do your own turbo kit right, then it takes a while..
if you cant hold off to get the simple parts that you NEED, then you need to be not trying to do your own turbo kit, and you should go buy one of RRMS kits instead.
__________________
13.4@109street tires 12.8@111 on 22x8 slicks..
Offline
Mar 30, 2009, 12:01 PM
Personal Sales Rating: ( 5)
Drives: 2004 lancer
I agree, but to answer your question you can run 7psi on your stock car but you will need a greddy E-manage or apexi safc 2, ect. basically an air feul controller
Offline
Mar 30, 2009, 12:33 PM
Drives: audi TT
7psi with a FMU worked for me on a gt28r
__________________
stroked and tons of boost
Offline
Mar 30, 2009, 05:23 PM
200$ for new injectors, new fuel pump, and new fpr?
Offline
Mar 30, 2009, 06:58 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Quote:
You can get some used wrx 440cc injectors and a new walbro 255 lph fuel pump for about $200. You would jut have to pony up $40-200 for the fpr...
Offline
Mar 30, 2009, 07:08 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
$100 for used 440cc WRX injectors
(optional $100 for getting the injectors cleaned and flow tested to make sure they're working)
$90 for walbro fuel pump
$140 for FPR
Depending on which FPR you go with, you'll have to buy a gauge that'll go on the FPR, fittings, fuel lines, which isn't cheap.
Online
Mar 30, 2009, 07:57 PM
sorry that came off rude, but you should just make your own turbo thread and keep updating it with questions, and post up anything you have purchased and pictures also, helps out the community alot
Quote:
incorrect, you do not need greddy e-manage or apexi safc2, evoscan/ECUflash work perfectly for lower boost applications, anything beyond the 10psi mark i would suggest just upgrading to a standalone since our cars ecu does not correct fuel maps for boost
Quote:
if you read further into boosting our cars, they are considered good up to about 7psi and nothing further, but why spend the money on a part that you will just need to replace later if you ever want more boost, and you will, boost is addicting
no 200 for just used wrx injectors and a new fuel pump, fpr isnt 100% needed if you get your car tuned properly
$140 for FPR
the aem FPR is a direct fit from what i was told by a few other lancer turbo guys
__________________
Offline
Mar 30, 2009, 08:23 PM
yeah ill be making a thread soon to show progress on turbo'ing my car im just still trying to figure everything out.
what exactly is evo scan or ecu flash? is it simmilar to a AFC
and getting it tuned properly do you mean taking it down to a shop and having it proffestionly tuned.
or just having it tuned by somone thats knows how and has done it before.
Offline
Mar 30, 2009, 09:43 PM
i would recommend using a professional. if a local shop tunes a decent amount of evos, they can use the same program on your car to log and tune with. ecuflash is just the most commonly used program.
i normally suggest to all my local guys to use TouringBubble (evom alias) he has done a great job on my car with were its at right now.
-Daniel
__________________
Offline
Mar 30, 2009, 10:07 PM
-Daniel
yeah i got that ecu flash but its foreign to me.
but i have a friend thats tuned his own cars forever and hes had about 14 of em hes currently driving a 96 eclipse.
ill have to look around locally and see if there are any good places to tune around here.
Offline
Mar 30, 2009, 10:56 PM
try the regional forum for your area.
__________________
Offline
Mar 30, 2009, 11:44 PM
alright thanks ill check that out.
also i was wondering after the turbo is installed do you need to have the car trailered to a shop or is it ok to drive temp to get it their. if theres not one in town i might be driving about 4 hours to get to one
Offline
Mar 31, 2009, 08:34 PM
ewww.. well im not 100% sure... i would have to say it depends on the setup and what turbo and everything.. but i know of a few guys that havent been tuned yet and they drive them..
my car couldnt even idle when we first started her up.. luckly my tuner came to the fab shop to dial the car in a little just so i could drive her home.. but the car needs to be tuned asap..
__________________
Offline
Apr 1, 2009, 11:39 AM
Drives: audi TT
Because none of this **** was out when i had my lancer. The only option was a rrm kit or tsi. I imported the RPW hardware and the fmu worked well enough for what was available 3+ years ago. Not to mention i think i would survive loosing out on like the $50 i spent on one
__________________
Offline
Tags
06, 440cc, audi, boost, es, fuel, injector, injectors, installing, kit, lancer, oz, stock, tt, tuned, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
