Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 21, 2009, 08:18 PM   #1
Personal Sales Rating: (0)
Drives: 2005 lancer es
internal / external wastegate turbos
opinions on these?
my first plan was to go with a external but my friend said i would save alot of time and money going with an internal one?
has anyone had experience with both of these?
feed back greatly appreciated.
Offline
Old Mar 22, 2009, 01:44 AM   #2
Personal Sales Rating: (7)
Demon_ni2's Avatar
Drives: BIG Turbo OZ
Send a message via AIM to Demon_ni2
well your friend is correct. your internal wastegates will normally cost less.. one reason is because u dont have to purchase the wastegate.. i enjoy my setup, its a t3 with an external tial 38mm.. car sounds good and i like the looks of the external turbo setups.. if your going for cheap as possible.. then a used (or even new) turbo with an internal wastegate is the cheapest option.. other wise your be purchasing mutiple items that are very cheap..
plus u have to remember about your manifold.. not many manifolds are setup for a 4g94 with an external wastegate, so u would be looking at a custom built manifold also.. not very cost effective..(my setup cost me an arm and a leg, but i love it, its unique and it looks great)
do what you want.. but your friend is correct, normally a internal wastegated turbo u can get for cheaper(most OEM turbos have internals, and there are alot floating around).
__________________
EPM built - Custom 60 Trim t3 Turbo Lancer - Built by Q@evopowermods - tuned by TouringBubble
13.4@109street tires 12.8@111 on 22x8 slicks..
click here ---> MY TURBO KIT IS FOR SALE!!!! <--- click here
Offline
Old Mar 22, 2009, 10:14 AM   #3
cincy's Avatar
Drives: audi TT
All depends... as usual. If you plan using a turbo that meets your needs best, an internal wastegate is fine. The only time its bad, is when you try to run a turbo that really moves alot of air and you only use a small amount of its capabilities. THis would cause boost creep. THis is the reason you see lots of honda guys running very large turbos at 8-10psi and larger 40-44mm wastegates.
__________________
stroked and tons of boost
Offline
Old Mar 23, 2009, 12:52 AM   #4
another question i have is the 16g turbo that come stock on lancers is that internal or external wastegate?
and can the manifold on speedcorps be used with external or interal wastegate all you do it cap the opening right?
thanks again for your responses
Offline
Old Mar 23, 2009, 02:03 AM   #5
Personal Sales Rating: (21)
ThunderOZ's Avatar
Drives: 02 Lancer OZ 16G TURBO
Send a message via AIM to ThunderOZ Send a message via Yahoo to ThunderOZ
The turbo on the Lancer Evolution is a 16g, internally wastegated. The Speed Corps manifold is set up for the stock setup(internal).
__________________
-Merc
Build thread on Mitsu-Media
Cardomain
Offline
Old Mar 23, 2009, 01:27 PM   #6
Quote:
you just made my day
thanks for the reply
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
