Feb 11, 2009, 08:12 PM
Personal Sales Rating: ( 0)
Drives: Lancer Oz Turbo'D
bov
hi im just want to know how i know that mi bov is working?, do it have to make any sound?, also how to adjust the bov is a greddy type s.
Offline
Feb 11, 2009, 09:27 PM
Personal Sales Rating: ( 7)
Drives: BIG Turbo OZ
well when you dont have the recircualtion pipe hooked up, and the car is idleing.. is there any vaccume to it? it should be sucking in a little air when its idleing..
if you didnt remove 1 spring from the inside, then it might not be sucking in air, and it will more then likely not purge either..
it might cause the car to stall but you could raise the revs and little to get it into boost so bov will purge when you let off.
if it doesnt purge, its not working!
__________________
13.4@109street tires 12.8@111 on 22x8 slicks..
Offline
Feb 11, 2009, 09:44 PM
Drives: audi TT
When you shift, it wont jerk like it should have when you had no valve on in the first place. You should still hear the valve release even if its recirculated since you probably arent using an airbox and also have metal pipes
__________________
stroked and tons of boost
Offline
Feb 12, 2009, 07:22 PM
ok, thnks demon you really help me alot, the bov is working know, just remove th spring like you said. and yes know the sound is only the bov, it sound nice, even it is in recirculating mode. how you know the bov adjustment is the perfect one?
Offline
Feb 12, 2009, 07:26 PM
Drives: audi TT
it shoulds clean with no flutter while still holding the set psi
__________________
Offline
Feb 13, 2009, 01:22 PM
Drives: 2004 Ralliart Turbo
Well i have a Blitz dd bov, on my lancer ralliart. And it is recurculated, and it flutters. So i took the recurculation tub off, and just left the tube hanging there, it blew off sounded great even at low RMPS (and yes i already did loosent he spring). So i drove it in the rod a little bit and it was smooth as can be, but then when i put the recurculationt ube back on and drove it around ir bucked down when i shifted felt rough, did'nt realize it since i had never had it smooth just thought that was the way it was, it is'nt a huge jerk just little like it is restricted or somthing. Anyone help?
__________________
2004 Turbo Ralliart
Custom T4 turbo kit
Road///Race sway bar and perches
Road///Race CF engine cover
Tein S-Tech springs
SplitSecond ECU
BLitz BLM gauges
Raze R-74 17x7, Toyo Proxy4 wrapped
My car FOR SALE http://forums.evolutionm.net/sale-ca...art-300hp.html
*FOR SALE* -
Apexi S-AFC II special edition
EVO8 plug and play harness
(PM me for details)
Offline
Feb 13, 2009, 01:26 PM
Drives: audi TT
you loosened the valve when you vta and tightened it when you recirculated it??
__________________
Offline
Feb 13, 2009, 01:36 PM
CINCY did you read my thread? http://forums.evolutionm.net/lancer-...er-please.html This is the problem im hacing it explains everythingi have tried last night while tinkering around with it check it out, also you can e-mail me at ski10804life@yahoo.com i willr espond faster this way, if you know about this issue and think you can help i am looking for someone tho help me very badly just shoot me an e-mail at that adress thanks man
__________________
2004 Turbo Ralliart
Custom T4 turbo kit
Tein S-Tech springs
SplitSecond ECU
BLitz BLM gauges
*FOR SALE* -
(PM me for details)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
