Feb 9, 2009, 08:09 AM
Personal Sales Rating: ( 2)
2003 Mitsubishi Lancer
Drives: 2003 Lancer esturbo
03 lancer es Evo 8 build
Tuned at 180 hp untill i figure out how to rescale my ecu then its 230hp and one hell of a ride....deffinitely a build to take on.
I was a complete noob at this when i started in febuary of 09 and from all the help i had from this site i was able to put on this custom turbo by myself for the most part. The car is so fun even now when its not tuned fully!!! : ) im trying to make a list of everything u need and videos will be posted too along with pics.
What You WILL NEED:
Turbo Manifold from www.speedcorps.com
Evo 8 16g Turbo with 10.5 hotside from pbevo12
From Magicmared:
Evo 9 Downpipe
Evo 9 Intercooler
Evo 9 Intercooler Piping
Evo 9 intake Pipe
Wrx 440 cc Injectors ( keep stock rubber ring and spacer) from a neighbor
Walbro 255 fuel pump from www.speedcorps.com
Forge adjustable Wastegate Actuator
7 - 10 pound actuator spring from www.speedcorps.com
Manual Boost controller from www.speedcorps.com
Innovate LC-1 Wideband from www.speedcorps.com
fuel pressure regulator from www.speedcorps.com
blue couplers www.speedcorps.com
Greddy Blow Off Valve Type RS comes with recirc adapter from www.speedcorps.com
clutchmaster stage 3 from www.speedcorps.com
10" push/pull Slim Fan from advanced auto parts!
fragola ss braided steel line ( 4 feet - 4an )
Felpro exhaust manifold gasket ( metal )
OEM evo 8 manifold to turbo gasket
Skull shift knob
Carbon Fiber Autometer Boostgauge
Triple pillar from lancer shop
NEW waterpump, timing belt, and throwout bearing.
5/8 heater hose 90 degree bend ( 1 foot )
5/8 hose fitting
- 6an to hose barb fitting
1/2 inch 90 degree to - 6 an female
-6an male to - 4an male
oil feed to turbo fitting can be done in 2 ways, ill get the details
RTV silicone gasket sealer
1 bolt ( M8 x 1.25 ) for the left lower intercooler pipe
radiator mount kit
kinda straight but not lol radiator hose for BOV to Upper intercooler pipe ( 1 foot )
break cleaner fluid.....rags.....
little breather filter
lots of 1/4 inch hose
teflon tape
injector o - rings
valve cover gasket
5w 30 oil
75 85 gear oil
antifreeze
brake fluid
exhaust flange from meineke, try get a 3 inch but they do have one that matches the evo 8/9 downpipe
Tien Lowering springs
__________________
.:. 03 Lancer ES TURBO.:.
.:. AIT RACING FF2 BODY KIT .:.
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. Electric Blue Perl .:.
.:. stage 3 fx300 .:.
.:. Full 3 inch magnaflow.:.
.:. Greddy Rs .:. rrrRRRR(PSHhhh)rrrRRr
.:. fully built .:.
Offline
Feb 9, 2009, 08:12 AM
if substitutions can be made then please let me know
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Feb 9, 2009, 08:17 AM
Former Vendor
Personal Sales Rating: ( 27)
2008 Volkswagen GTI
Drives: GTI MkV
we also have the wastegate actuator, AEM wideband, fuel pump, and if you want you can pick up a full 3" evo downpipe from us too.
__________________
THIS SPACE FOR RENT
Offline
Feb 9, 2009, 08:33 AM
could i get the wastegate actuator 7-10psi spring and put it in the stock evo 8 one, is that possible
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Feb 9, 2009, 08:39 AM
Drives: 16g 4g94
i don't think so. You need the forge adjustable one i believe.
Offline
Feb 9, 2009, 08:40 AM
Drives: 16g 4g94
just about everything that list can be found used here on the forums btw. Just takes time to search. Took me 4 months to gather my parts.
Offline
Feb 9, 2009, 08:41 AM
yeea im searching lol
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Feb 9, 2009, 08:49 AM
Personal Sales Rating: ( 7)
Drives: BIG Turbo OZ
good list zulu. jump on nasoic forum for those wrx injectors, i dont think ill be selling mine anytime soon. (might be like june till i switch them up)
__________________
13.4@109street tires 12.8@111 on 22x8 slicks..
Offline
Feb 9, 2009, 08:51 AM
k thanks demon
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Feb 11, 2009, 09:55 PM
probably will make them!
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Feb 18, 2009, 09:41 PM
Personal Sales Rating: ( 9)
Drives: Evolution
i have no idea bout lancer blocks, can it withstand the boost? how much boost will you be running?
__________________
aem intake, hks ti catback, invidia test pipe, downpipe, ported mani, hks 272s, fidenza camgears, 1200cc injectors, motor mounts, torque dampener, fp green turbo, ams intercooler and piping, hks ss bov, aem ems, cosworth head studs, walbro 255 fuel pump, hks DLI ignition amplifier, apexi n1 coil, act 2700, ams mini battery, slotted rotors, defi boost, egt, oil temp, aem wideband, apexi tt,e85. 426whp @ 27psi
Offline
Feb 18, 2009, 09:43 PM
7 psi
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Feb 19, 2009, 02:21 AM
Personal Sales Rating: ( 0)
Drives: IX MR SE
The stock wastegate actuator is 11.5 psi ... you don't need the Forge unit for your application. It will boost 18 psi+ with that actuator installed.
Offline
Feb 19, 2009, 05:33 AM
i can only boost 7 - 10 so im installing that type of spring in it plus i have stock one for when i build the internals
__________________
.:. K&N .:.
.:. Evo 8 Wing .:.
.:. 17" Rims .:.
.:. fully built .:.
Offline
Tags
16g, blue, body, custom, customized, es, evo, evo 8 parts needed, kit, lancer, speed corps, stock, t3, turbo, zulu989  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
