Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Aftermarket Forced Induction Tech
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 5, 2009, 05:19 PM   #1
Personal Sales Rating: (0)
carlosdevil10's Avatar
Drives: Lancer Oz Turbo'D
trouble, dont know why
just want to know how to fix this, i m boosting 7 psi, and all is runnig well, but sometimes when stop accelerating and put into second shift or no speed the car just turn off, just turn off. the car only turn off afeter putting it to high speed and then stoping , only turn off when stoping . sorry about my english i am from guatemela
Offline
Old Feb 5, 2009, 05:31 PM   #2
Personal Sales Rating: (27)
lilazn64's Avatar
Drives: 16g 4g94
Send a message via AIM to lilazn64
Boost leak sounds like your problem. Check the turbo, intake pipe, j-pipe and make sure the nipples are capped. Also, make sure your clamps are tight
I had the same problem and I went to the local auto parts store and bought the variety of vacuum caps. Fixed it right up!
__________________
My Lancer
Offline
Old Feb 5, 2009, 05:36 PM   #3
doctorjon's Avatar
Drives: TurboCharged Mitsubishi Lancer OZ-Rally
Not only that, but check your MAF. Other than that sounds like a boost leak.
__________________
pushing the limits of my stock 4g94 (turbo'd)
Offline
Old Feb 5, 2009, 05:41 PM   #4
Personal Sales Rating: (12)
4g94T's Avatar
Drives: corn fed turbo lancer
ditch the worm clamps and go with t-bolt clamps, you'll never have to worry about boost leaks!
i also changed all my couplers to 4 ply silicone couplers.
Offline
Old Feb 5, 2009, 06:00 PM   #5
so it is a boost leak, u hace some t-bolts on and somo normal, so change it all to t-bolts, the maf could it be?, so the leak is in the couplers or something alike?, when i disconnect the sensor it works fine
Offline
Old Feb 6, 2009, 08:59 AM   #6
lilazn64's Avatar
Drives: 16g 4g94
did you install the MAF backwards?
__________________
My Lancer
Offline
Old Feb 6, 2009, 08:18 PM   #7
nop, the maf is in the right way, i think is the maf, could it be the vacuum line?
Offline
Old Feb 6, 2009, 08:25 PM   #8
Personal Sales Rating: (6)
03_Lancer_ES's Avatar
Drives: 2003 Mitsubishi Lancer
did the car throw out any service engine soon codes?
__________________
Quote:
Originally Posted by otter View Post
I don't like the handicapped stalls. I feel like I'm too far away from the door to prevent someone from barging in (this has happened before), since the locks on stalls usually suck. Some 4-5 y.o. kid pushed his way through the lock, saw me, turned around and left, leaving the door hanging open. Couldn't immediately shut it due to my ass being in the middle of birthing something unholy.
As for the urinal rules, most guys put way too much thought into it.
Offline
Old Feb 6, 2009, 09:17 PM   #9
Personal Sales Rating: (7)
Demon_ni2's Avatar
Drives: BIG Turbo OZ
Send a message via AIM to Demon_ni2
T bolt clamps are a good idea.. but 4ply couplers? (going for 60+psi?)
good couplers are a must (i still need to upgrade a few of mine)
but no point in the overkill on the couplers, unless price is about the same.
stalling could also be a fueling issue. hate to say it, but 4+ people saying boost leak, and not one saying fuel/tune? i know my car will flood out every once and while when i downshift, but i normally catch it and raise the revs a little.
(sorry i don't know your car better, but is this a new turbo install? or an old one that has been tuned and working fine for a while?)
-if it is tuned, and you havent been having any problems pervious to this, just ignore me.
__________________
EPM built - Custom 60 Trim t3 Turbo Lancer - Built by Q@evopowermods - tuned by TouringBubble
13.4@109street tires 12.8@111 on 22x8 slicks..
click here ---> MY TURBO KIT IS FOR SALE!!!! <--- click here
Offline
Old Feb 7, 2009, 09:58 AM   #10
cincy's Avatar
Drives: audi TT
A boost leak would be more possible. It would have to be a significant leak for it to stall out the car. However, if the fuel on deceleration was way to much, that could also stall out the car since it will give the same effects.
You can build a simple pressure tester for cheap and test the system for the leak. If none is found, tuning is the next place to look.
This is all taking into account you are not using a vta bov that is causing the problem
__________________
stroked and tons of boost
Offline
Old Feb 7, 2009, 10:53 AM   #11
ok, im still not using a bov, could it be that?, i think maybe is the fuel, it oly make it in 2nd shift yesterday i try it in 3rd and all was ok. if accelerating the car more could help?, now the idle acceleration is under 1. also it is not throwing check engine light.
Offline
Old Feb 7, 2009, 11:04 AM   #12
Personal Sales Rating: (21)
ThunderOZ's Avatar
Drives: 02 Lancer OZ 16G TURBO
Send a message via AIM to ThunderOZ Send a message via Yahoo to ThunderOZ
Wait you don't have a bov at all?
__________________
-Merc
Build thread on Mitsu-Media
Cardomain
Offline
Old Feb 7, 2009, 11:56 AM   #13
nop, i still waiting for it, it have not arrive yet.
Offline
Old Feb 7, 2009, 12:28 PM   #14
cincy's Avatar
Drives: audi TT
PLEAST STOP DRIVING YOUR CAR!!! YOu are shocking the **** out of your turbo and will blow it, if you havent already. You HAVE TO HAVE a valve on the car
__________________
Offline
Old Feb 7, 2009, 12:37 PM   #15
cincy's Avatar
Drives: audi TT
Just noticed you are the SAME guy that completely screwed up his oil/water lines. You really need to find someone else to do the work on your car
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
