Jul 4, 2009, 12:46 AM
#106
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Make sure you have some kind of spreadsheet app to veiw your logs, fist time I opened up a log I just about fell over lol it was in notepad but when I dl openecu and used that it make a world of difference
__________________
16G Turbo build: Build completed tuning time
Offline
Jul 4, 2009, 10:12 AM
#107
Personal Sales Rating: ( 4)
2003 Mitsubishi Lancer
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
yup already got office on my tuning comp, because as of now my 5th injector setup is based off of like microsoft access. so it was already needed.
Online
Jul 8, 2009, 10:36 PM
#108
Personal Sales Rating: ( 1)
Drives: Lancer OZ Rally 2002
Did u upgrade ur radiator? Does anyone know if and evo 8/9 rad will drop into an 02 lancer OZ?
Offline
Jul 8, 2009, 10:51 PM
#109
I remember someone is Zulus thread I think saying it will fit with no issues
__________________
Offline
Jul 12, 2009, 10:15 PM
#110
im pretty sure that it does fit, BUT i did hear from a guy who works at the mitsu dealer here in madison say it wont, but take that with a grain of salt cause ive had problems with them before as well.
was finally bale to do some data logging and i have 3 logs to look at. the last one is just kinda playin around, the first one is a trip from weaver auto parts in waunakee where i work and live down to my other work at rc performance and hobbies, all in all approx 25min drive in traffic, and the second one is right after i changed my oiland spark plugs, because i was getting a cylinder 2 misfire, so i changed the plugs and i havent had the problem since. any ideas? cause plugs didnt look too bad.
Online
Jul 12, 2009, 10:56 PM
#111
here is a pic of my old plugs.
Online
Jul 13, 2009, 02:03 PM
#112
Personal Sales Rating: ( 0)
Drives: audi TT
what heat range and gap are you running? The gap should be ~.04 smaller than stock and 7 heat range
__________________
stroked and tons of boost
Offline
Jul 13, 2009, 04:17 PM
#113
im runnin the ngk 2756 which is a bkr6e-11
do you think the 7 would be better? i just put new 2756's in and havent had a problem since and no cylinder 2 misfires like i had before.
Online
Jul 13, 2009, 07:15 PM
#114
Drives: audi TT
for your power level, 6's should be fine, its the gap which you need to keep an eye on. Go back and measure the gaps on the plugs you pulled and i bet the one that is cyl 2 was .02+ bigger
__________________
Offline
Jul 13, 2009, 10:18 PM
#115
i will definatley look at that when i have time tomorrow. i never did think of that.
Online
Jul 25, 2009, 09:39 AM
#116
well i got my 501 maf yesterday and i plan on starting to tune it either today or tomorrow. also picked up the evo 8 gauge cluster because i like the look of it.
Online
Jul 26, 2009, 12:25 AM
#117
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Just curious, what did you gap the plugs to?
Offline
Jul 26, 2009, 08:48 AM
#118
which ones? the new ones were gapped at an .040 and the old ones when i pulled them out were an .045 on all of them so im not sure why i was only gettting a misfire on 2.
got the 501 eclipse maf in yesterday and the ecu flashed to accomodate it as well. havent logged anything yet but it seems to be smoother coming into boost now!
Online
Jul 26, 2009, 09:02 AM
#119
Personal Sales Rating: ( 14)
Drives: '03 Evo brain'd Lancer OZ-T
Quote:
Great to hear. You've now eliminated another restriction on your intake side. The smoother you can get air into your engine, the better your turbo will spool and the process repeats!
__________________
Evo ECU Swap for 4G94 Lancers: How-To
4G94 Lancer EcuFlash Master Definition List: Download
4G94 Lancer Bigger MAF Swap: How-To
Lancer Factory Service Manuals: Download
Offline
Jul 26, 2009, 09:10 AM
#120
o and also a big thanks to senate for the eclipse maf values!
and on a side note i got my subaru wrx 440 injectors from work a few days ago. less than $40 per injector from gb remanufacturing! and nice thing is if they dont work i can send them back!
Online
Tags
02, 1500, 2009, adding, aftermarket, antifreeze, custom, dodge, entry, es, full, lancer, lancer oz, mitsubishi, overheatr, radiator, ram, remote, size, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
