Oct 17, 2009, 07:20 AM
#256
Personal Sales Rating: ( 5)
2003 Mitsubishi Lancer
Drives: 2003 turbo OZ Greddy Boost Controlled at 11psi!
o crap that right. man i need to lay off some of the booze on friday nites. lol. ill have to do some checking for what i have checked in evoscan.
Offline
Oct 18, 2009, 07:47 PM
#257
well i found out that i didnt have that checked, so now back to doing some logging.
got the lower pipe on finally! here is the pic:
josh
Offline
Oct 18, 2009, 10:32 PM
#258
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
Is that a 4" intercooler?
eBay or AMS?
Offline
Oct 18, 2009, 11:00 PM
#259
ams ebay knock off. i had to do a little trimming on the bumper to make it fit. but for the price i got it for i couldnt beat it.
josh
Offline
Oct 18, 2009, 11:09 PM
#260
How's the quality?
Does it heatsoak after back to back pulls?
Offline
Oct 19, 2009, 09:21 AM
#261
it holds up really well. doesnt seem to have a probblem with heat saoking. pull after pull it holds strong.
Offline
Oct 19, 2009, 11:51 AM
#262
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
Well that's probably b/c it's 4" thick
Offline
Oct 19, 2009, 03:59 PM
#263
ok so i FINALLY had time to compression test my car.
piston:
1. 125
2. 125
3. 130
4. 125
i know that minimum is sposed to be like 170 correct? this doesnt look too good to me....
it runs strong even under boost but my numbers im hesitant.
josh
Offline
Oct 19, 2009, 04:42 PM
#264
Personal Sales Rating: ( 13)
Drives: 2003 Lancer ES-T 2001 Civic LX 2001 Dodge Ram 1500 Pickup
Wow dude that is really low. My understanding is 170 is minimum and is supposed to be over 200!!! How did you do it were you able to thread in the tester or did you have to press and hold it in there. I would imagine with that low of compression you would have a noticable loss in power
__________________
16G Turbo build: Build completed tuning time
Offline
Oct 19, 2009, 04:53 PM
#265
Personal Sales Rating: ( 1)
Drives: TB IX MR SE, 07 R6
josh
Did you install the rust your self too?
__________________
E85
Quote:
Found a driedout gerbil carcass at the bottom of the box—AND it had been shaved.
Offline
Oct 19, 2009, 04:55 PM
#266
nope threaded it in until it stopped on the extension, then threaded in the tester until it stopped and was tight.
the only other thing i can think of is that my car hadne tbeen run since 1230 when i got back from lunch and i tested it cold about 3.5 to 4 hours later. i will try it again tonie when shes a little warm and go from there. if that dont work then i will try another tester (as a just in case, bu ti just bought that tester like a month ago and have never used it)
like i said im a little hesitant and there is definatley no noticeable loss in power.
Offline
Oct 19, 2009, 04:56 PM
#267
Quote:
yup the wisconsin winters helped with that one
Offline
Oct 19, 2009, 04:58 PM
#268
Personal Sales Rating: ( 2)
2002 Mitsubishi Lancer
Drives: 02 lancer oz 74/76/79 Corvettes
How many times did you crank it for the test? they do all seem low but they are very close to each other so i really wouldnt worry to much about it.
__________________
Budget Turbo :P installed Custom Borla cat back 2.5,Fidanza flywheel, Act xtss, 4g93 intake, injectors 275cc, Auto meter Gauges, Injen CAI,High flow Cat,aeromotive 1:1 fpr, Walbro 255, circle earth ground
on hand 16g6 with 10.5 hotside,Ported&polished head,Megan Racing 3" downpipe, Intercooler and piping, Greddy BOV rs, guage pods, gates racing belt, Forge wastegate with spring, tactrix cables, 16g manifold, oil feed
Needs injectors
Offline
Oct 19, 2009, 05:11 PM
#269
5-7 times like it said in the instructions that came with it.
man im starting to freak out!!!!!
those number just worry me a little more than a bit....
josh
Offline
Oct 19, 2009, 05:19 PM
#270
They are consistant. Thanks what matter's do you have the throttle plate help open? that makes a big differance.
__________________
Needs injectors
Offline
Tags
02, 1500, 2009, adding, aftermarket, antifreeze, custom, dodge, entry, es, full, lancer, lancer oz, mitsubishi, overheatr, radiator, ram, remote, size, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
