Jul 14, 2007, 01:27 AM
Personal Sales Rating: ( 0)
Drives: 08 Lancer GTS, 06 EVO IX
I talked to RRM today and they said as long as you have the money they will hook that $h!t (turbo) up to your cvt lancer.
Offline
Jul 14, 2007, 07:09 PM
Drives: 2008 Mitsubishi Lancer GTS
Quote:
Well, for money anyone will hook anything up to your car; now will it blow up your engine is the big question.
__________________
Color: Apex Silver
Transmission: CVT
Accessories: Sun and Sound, Navigation Tech Packages
Mods:
[X] RRM intake
[X] RRM Axel Back Exhaust
[ ] Tinted Windows
[ ] Debadged rear
[ ] CF Hood
[ ] Turbo Kit
[X] RRM pulley
[ ] RRM Rear Upper Strutbar
[ ] RRM Lower Truss Bar
[ ] RRM Lower Tiebar Set
Offline
Jul 14, 2007, 08:46 PM
^^^^ ha that is soo true.
Offline
Jul 15, 2007, 06:29 AM
Drives: 2008 Lancer GTS w/ S&S & Navi
One advantage, is the fact that the CVT is using a timing chain, opposed to a belt, therefore allowing for more power and stress on it...
Just my 2 cents...
Offline
Jul 16, 2007, 12:14 PM
Drives: '08 Blue Lancer GTS, '95 White Mustang GT, '74 Black Camaro
no, our CVT uses a belt/pully. Not a chain. If it had a chain like the Audi A4 and other turbo CVT cars, it would be fine. but, we dont.
__________________
Owner of the First 2008 Electric Blue GTS Fully Equipped W/ Smashed Driver Side Door.
Offline
Jul 16, 2007, 04:20 PM
CVT uses a timing chain.....
"Using a timing chain instead of a belt – as many engines in the segment use – allows for a more compact design, helps ensure reliability and eliminates the need for belt replacement."
http://www.autoblog.com/2007/01/08/d...ype-x-concept/
"Mitsubishi says the Lancer's engine has a timing chain instead of the belt used by many competitors, which helps ensure reliability and eliminates the need for belt replacement."
http://research.cars.com/go/crp/rese...&revlogtype=22
video even says how to remove "timing CHAIN" (4:09)
http://youtube.com/watch?v=Bb4zdcD0G-Y
Offline
Jul 16, 2007, 04:33 PM
Drives: 2000 Dodge Neon
I think we got a little confused here... All 08 Lancer's have a timing chain in the engine. Yes, that does help the engine be more robust and withstand higher power and RPMs.
The Lancer CVTs have a belt in the transmission that transfers power between pulleys whereas the Audi CVTs have a chain. As far as I know, the chain-based CVTs can withstand more torque then the belt-based CVTs.
Offline
Jul 17, 2007, 06:31 PM
I agree, there was some confusion there... On the other hand, I think our "steel" belt should be able to withstand just as much torque as a chain, and I would also speculate that the "steel" belt is much lighter than the chain and also should have more give than a chain...
IMO, anyway... I may be wrong...
Offline
Jul 17, 2007, 07:28 PM
CVT torque handling capability is limited by the strength of their belt or chain, and by their ability to withstand friction wear between torque source and transmission medium for friction-driven CVTs. CVTs in production prior to 2005 are predominantly belt or chain driven and therefore typically limited to low powered cars and other light duty applications. More advanced IVT units (Which is what our Lancer has, I believe)using advanced lubricants, however, have been proven to support any amount of torque in production vehicles, including that used for buses, heavy trucks, and earth moving equipment.
Offline
Jul 18, 2007, 07:17 AM
haha whoops... i just read the word chain and instantly thought people were trying to say this was a chain CVT and not a belt/pulley. my B
And as far as the IVT goes, i remembe reading alot on "how things work" or some wiki about that but i swore it WASNT our car. Could be wrong though but ill check all my sources later and get back to it.
In the mean time someone blow something up, its getting boring
__________________
Offline
Aug 2, 2007, 07:18 PM
Drives: Boosted 08 Lancer GTS
Quote:
Originally Posted by GroundZero
i talked to RRM they said a kit will be out by end of this summer
And I will be one of the first to buy it.
Offline
Aug 3, 2007, 07:04 AM
Personal Sales Rating: ( 4)
2009 Mitsubishi Lancer
Drives: 2009 Lancer Ralliart w/ Navi/EvoX FMIC/MR RECARO
Quote:
guess again...
__________________
TUNED BY MOTION LAB
-3 port electronic boost controller
-UR catback
-K and N SRI
-EVO X FMIC
-INJEN UICP
-EVO X BOV
305WHP and 329 lbs/ft of TRQ
http://img41.imageshack.us/img41/9052/scan0001bv.jpg <<<----DYNO SHEET
Factory ( 237whp 250 lbs/ft of TRQ )
TTP (281WHP 298lbs/ft of TRQ)
Offline
Aug 3, 2007, 07:39 AM
I said one of the first, not THE first. Unless Rob lets me be a tester again like the piggy.
Offline
Aug 3, 2007, 07:44 AM
hahahah i was just playing around, but yes i am gettng that kit, i probably wont be the first, already have 2k saved for it, i am sure it will run somewhere near 4k range.
__________________
TUNED BY MOTION LAB
-UR catback
-K and N SRI
-EVO X FMIC
-INJEN UICP
-EVO X BOV
Offline
Aug 3, 2007, 07:51 AM
Drives: 2008 Lancer ES
I'm right there with you guys. As soon as they have a few to sell I'm jumping on it. Got money burning a hole in my pocket and need my turbo fix. Then all will be right in the world...... well for now.
__________________
http://registry.evolutionm.net/viewride.php?vid=5431
Mods: RRM rear swaybar, RRM front strut bar , RRM SRI, RRM Piggyback, RRM pulley, RRM motor mounts, RRM lower tie bars, RRM lower truss bar, RRM lowering springs, RRM rear strut bar, Custom exhaust, black graphics, painted bumper lip and grill, painted engine cover, tint, tinted tailights, spoiler, debadged rear, 18" DZ black rims, shift light, triple gauge pod, 7" Jensen Flipout DVD, 2 infiniti 12, Sony class D amp, custom foglight install
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
