Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Interior/Exterior/Electrical
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 28, 2009, 02:35 PM   #1
Personal Sales Rating: (8)
jezefink's Avatar
Drives: Ww evo VIII
gauge cluster issue and sun roof issue
so...my car has been down for about a year...finally got it back together ..working out all the little gremlins from sitting for so long...heres my problem
the gauge cluster is dim on the right side IE...temp gauge/gas gauge/ and part of my rpm gauge..this worked ok..with the headlights on before the motor went...now heres the weird part..all of a sudden it's on when the head lights are off..but when i turn the headlights on the whole cluster goes dark..
also i dont have my owners manual...i need to find the sunroof fuse and the rear wiper fuse ..i believe they are both blown..now by the drivers side kick panel it shows the sunroof fuse and says located above..but i can not find it...
any help would be appreciated..thanks
__________________
I was in the middle of a god damn reptile zoo...And somone was giving booze to these things..IT WONT BE LONG TILL THEY TEAR US TO SHREADS!!!!
WWW.DOGBOXRACING.COM
"im from the streets Biiiitch"
Offline
Old Sep 28, 2009, 02:40 PM   #2
Personal Sales Rating: (111)
Z_Lancer_Man's Avatar
Drives: 06 WW EVO IX w/ SSL
Send a message via AIM to Z_Lancer_Man
For the gauges dimming with the headlights on - as simple as this sounds, check your dimmer switch and make sure it's rotated to the brightest setting. When the headlights are off, the electrical system bypasses the dimmer and automatically sets all the gauge lighting to maximum brightness (so you can see it in the sunlight). However, once headlights are on, it goes through the dimmer, since some people have more sensitive night vision.
Hope it was just that!
__________________
AMS 3" TBE w/ TP |GFB BOV | AMS UICP | Muse LICP | Walbro 255 Fuel Pump | Mini Battery | Amsoil air filter w/ Vibrant MAF adapter | Custom Boost Pill (#58) | Omni Power 4-Bar MAP Sensor | Powerslot Slotted Cryo Rotors | Swift Springs | MIL.SPEC TB Shaft Seals
325/310 WHP/TQ (VDR 5.7) - 24 PSI, 91 Pump - Self Tuned w/ECUFlash
Previous Lancers
- '09 Lancer GTS (traded 6/19/09)
- '03 Lancer OZ Rally (traded 1/18/09)
Offline
Old Sep 28, 2009, 02:57 PM   #3
jezefink's Avatar
Drives: Ww evo VIII
its not the dimmer switch....i def checked that...the cluster will be on when the head lights are off and when the head lights are turned on the cluster literally goes black
i figured out why its dim on the right side....thanks to an old thread...the right bulb is burned out..but this still doesnt help with the cluster being reversed
__________________
Offline
Old Sep 28, 2009, 03:00 PM   #4
If it's totally blacking out then you have a blown fuse. The EVO cluster is never meant to turn off (hence why it burns up bulbs so quickly). Good luck.
__________________
Previous Lancers
Offline
Old Sep 28, 2009, 03:03 PM   #5
jezefink's Avatar
Drives: Ww evo VIII
if theres a blown fuse....wouldnt it just be out totally..rather than just turning off when the head lights are turned on
__________________
Offline
Old Sep 28, 2009, 03:12 PM   #6
Not necessarily - the headlight switch engages additional circuitry and an element in that circuit could be causing the problem. Perhaps you should just go through all your fuses one by one and see which ones are blown. As tedious as it sounds, it would help eliminate those as a source of the problem and its relatively easy and cheap. Always a good idea to start at the easiest and work your way up
__________________
Previous Lancers
Offline
Old Sep 28, 2009, 03:32 PM   #7
jezefink's Avatar
Drives: Ww evo VIII
nice....yeah i went through the fuses under the hood too..it was a 7.5 amper..that was blown..put a new one in..and wa la..golden..
thanks again...sunroof fuse looks fine..im guessing i have to tighten the two bolts under the head liner
__________________
Offline
Old Sep 28, 2009, 03:56 PM   #8
Glad you found it!
__________________
Previous Lancers
Offline
Old Sep 28, 2009, 05:36 PM   #9
Jp7
Personal Sales Rating: (0)
Jp7's Avatar
Drives: CT9A (MR/9) - Hopefully AE86 Soon
its nice when people can actually fix these gremlins!
Offline
Old Oct 25, 2009, 10:44 AM   #10
Personal Sales Rating: (3)
Drives: evo ix
If the right part of the dash doesn't illuminate because of a burnt out bulbwould that also cause the headlight icon not to illuminate on your dash as well?
__________________
Saving up...
Quote:
Originally Posted by TTP Engineering
I think he should use goat milk injection. Injen has a new kit coming out.
Offline
Old Oct 25, 2009, 05:43 PM   #11
Quote:
No. They are separate bulbs in the clusters.
__________________
Previous Lancers
Offline
Tags
blow, cluster, custom, easly, evo, fuses, gauge, gauges, issue, lancers, lights, mitsubishi, problem, problems, roof, sunroof, turned, viii
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
