I have not done it in a while but it is fairly easy. I will tell you the best I can remember without looking. You will have to remove the dome lamps. I do not know how many the rs has but a normal evo with has two, an evo with a sunroof has one. To do so pop off the lenses and remove the screws. You will also have to remove all the pillar trim. To remove the middle side pillar trim you will have to take off the seat belts. You just pop the cap off and take out the bolt on each. Once you pull the trim out you will be able to see how to work the belt out and get the trim all the way off All of the trim is held in by clips. I can not remember if you just pull or if they slide up then off. I know on the front you just pull them off. On the middle and rear I think you pull up on them first. It might be easier to get the rear off with the seat out. To take the seat out, pull the two tabs at the bottom and the cushion will pop right up. Then there will be two or three bolts that hold the back section on. Take them off and pull up on it. Then just pull it off and out one of the rear doors. After you have all the trim panels off, you will see the clips that hold the head liner on. Pop them out and it should drop down. At this point you will just have to work it out without messing it up.
Sorry if this post jumps around and is hard to follow. I am extremely tired and trying to get it done before my laptop dies or I pass out.
Let me know if you have any more questions
