Help with tail lights
Hey all. So i recently purchased an evo 8 from a guy on these forums. When i got it everything worked PERFECT. Now here is my dilemma. When my lights are off, all the lights work perfectly fine. Except on the left side rear turn signal is sort of dim. Now, when my lights are on, my left turn signal acts as the brake light and the brake lights act as the turn signals. So my lights are on and i step on the brake, the signal light lights up bright. When i turn signal left, the brake lights blink. When im turn signaling left while braking at the same time, it blinks very fast like a bulb is out. I have the jdm tails. I figured it would have to be wired incorrectly, but the previous owner says no cutting or splicing just a direct fit. Any information would be appreciated. Thanks!
