Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Interior/Exterior/Electrical
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 15, 2009, 04:29 PM   #1
Personal Sales Rating: (0)
Drives: 03 TB Evo
SRS light and horn issue
When i bought my car the SRS light was on and was told only the dealership can flash this to clear it as it was run off a seperate ECU of some sort.
Also, my horn will not work at all but it DOES work when i lock and unlock my car. (stock system). checked the coil or whatever and was told it may have been messed with if they had a quick release or something on there before.
this weekend I took my cluster out to put new bulbs in and the SRS light was off now but my horn still does not work.
so will my airbags deploy now? if the SRS had an issue like it did before i believe it would be fine now right? as long as the light is off.
Offline
Old Jul 16, 2009, 06:22 PM   #2
06WWMR's Avatar
Drives: 2006 Wicked White Lancer Evo MR
To be honest it sounds like you have a clock spring problem. The dealer will be one of the only places that can read the faults unless you find a good side shop that has the correct scanner for the air bag system. Most generic scanners wont work for airbags, especially on foreign cars. The srs light shouldn't of gone out just by changing the bulbs. Make sure the bulb is installed correctly. I'd say the most obvious answer, and if I were to throw parts at it, would be a clock spring. But, without seeing the fault for sure, I don't want you to go out and buy an expensive part if thats not the problem. My guess would be that the fault is for communication with the drivers air bag module. I'd call around and see who could run a quick scan for you.
Offline
Tags
06, car, clear, clearing, evo, evolution, evom, forums, lancer, light, srs, wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
