Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Interior/Exterior/Electrical
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 28, 2009, 09:06 AM   #1
Personal Sales Rating: (7)
Ricekiller81's Avatar
Drives: Evo VIII WW 05
Twin Walbro install(Question)
I recently Purchased a Full Blown Twin Pump assembly and I became a little confused on were to source my Constant 12V source for the 2nd Pump. For the 1st pump I just ran the (+) (-) Source of the existing wires of the OEM Fuel pump harness. I already have the 2nd Pump Relayed to the StandAlone's negative Trigger switch. I searched and found the Twin Pump Install thread, but it was unclear on were to source the power for the 2nd pump.
So can I:
1) Use the same 12V source of the Fuel Pump Harness, but Ground the 2nd pump off a different ground source?
2) Just Run a wire from tank to the front of the car to the Fuse box directly to the 12V source?
Thanks in advance
-Jon
Offline
Old May 28, 2009, 02:10 PM   #2
Thanks for the reply's anyone else?
Offline
Old May 28, 2009, 02:17 PM   #3
Personal Sales Rating: (0)
2004 Mitsubishi Lancer Evolution
My Garage
evoDON's Avatar
Drives: 2004 Mitsubishi Lancer Evolution VIII GSR SSL
Send a message via AIM to evoDON
i am wondering the same thing. i might have to do a twin walboro set up. anyone know?? thanks
__________________
- AMS 2.3L Stroker Kit W/ Oliver Rods
- ETS HTA3582 Twin Scroll Turbo Kit And 3.5" FMIC
- Exedy Twin Metallic Clutch
- AMS 1000HP Fuel System
- AEM EMS (Speed Density)
- Magnus V5 Cast Intake Manifold And BBK 75MM TB
- Brian Crower 280 Cams W/ Valves, Valve Springs and TI Retainers
- HKS Cam Gears
- AF Custom 4" Intake
- HKS Carbon/TI TB
- FIC 1050cc Injectors
- Mishimoto Radiator
- AMS Oil Cooler
- ETS Mini Battery
- HKS SSQ
- Hallman Pro RX Boost Controller
Applied Force
Offline
Old Jun 1, 2009, 07:20 AM   #4
Can anyone one post up what they know please.
Offline
Old Jun 1, 2009, 07:35 AM   #5
Personal Sales Rating: (3)
1992 Eagle Talon
My Garage
9sectalon's Avatar
Drives: EVO 8, Prius, Dodge Diesel
Run a 10g wire directly so there is no voltage drop. What is the Sellers recommendation?
__________________
2.3l, 272 cosworths, AEM, 1250cc, HTA86, FABWORX Forward Facing Manifold, Apexi Catback, Shep trans & transfer case. ACT, 255, PWR Fmic, Koyo mini rad, Okada coils, Magnus intake, 68mm Skunk TB.
Retired '92 FWD Talon 9.81@150
Offline
Old Jun 1, 2009, 07:58 AM   #6
Im unable to get a hold of them because of my Work hours. Thanks for the advice man
Offline
Old Jun 1, 2009, 10:07 AM   #7
Personal Sales Rating: (48)
2003 Mitsubishi Lancer Evolution
jid2's Avatar
Drives: 03 EVO VIII White
You need to run a new 12 V line with high current wire (I used 10 awg). DO NOT use the factory harness for both pumps. I tried it and it creates a massive voltage drop and neither pumps gets proper voltage.
I ran a fused line from the battery to my relay which is mounted in the trunk, then to the pump.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Old Jun 2, 2009, 07:03 AM   #8
1992 Eagle Talon
My Garage
9sectalon's Avatar
Let us know how that works out. I need to go dual on mine also.
Thanks
__________________
Offline
Old Jun 2, 2009, 07:36 AM   #9
Awsome thanks man that what I need to know. I see all of us runnung 2.3L Nice
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
