Apr 14, 2004, 03:55 PM
Personal Sales Rating: ( 0)
Drives: Mitsubishi Evo VIII
Wideband O2 sensor
Hi Folks,
I am seriously considering putting in a wideband O2 sensor for my EVO and have the Greddy e-manage and Profec e-01. Does the e-manage and or Profec e-01 have a 5 v output to handle controlling the output form the sensor?
Better yet has anyone installed an O2 sensor and used the e-manage with the profec e-01 for wideband sensing?
Thanks,
Tim
Offline
Apr 18, 2004, 09:27 PM
Personal Sales Rating: ( 21)
Drives: 05 element, 03 evo (mutating)
check this thread, pretty sure the guy is on this list too
http://www.innovatemotorsports.com/f...=&threadid=231
__________________
now with led dome lights!!!!!
Offline
May 29, 2004, 10:54 PM
Personal Sales Rating: ( 8)
Drives: '06 TB Evo IX SSL, '03 RR Evo VIII, '07 Jeep Grand Cherokee SRT-8
I got the Innovate LM1 wideband O2 to work with the Profec E-01 screen. You need the optional auxillary harness for the E-01, and the auxillary analog output cable for the LM1 to make it work. It's hot though..... AF ratio displayed on the E-01 screen.
Offline
Jun 1, 2004, 07:33 AM
So you bought the LSU 4.2 sensor, cable auxiliarry analog output cable and auxiliary input cable(e-01)?
How much did the set up run you?
Thanks,
Tim
Offline
Jun 1, 2004, 10:42 PM
Thanks,
Tim
The Innovate! LM-1 Wideband O2 (box/sensor/harness) costed around $350ish. The analog cable for the analog out of the LM-1 was around $10 or so. The auxillary input harness for the E-01 was $19.
Offline
Aug 5, 2004, 09:51 PM
Personal Sales Rating: ( 5)
Drives: 03 Yellow Evo, 90 Talon AWD
we use the additional input harness for the eo1 to log the 5v output from the AEM wideband gauge. works really well being able to log rpm, wideband, boost pressure, and airflow hz.
Offline
Aug 8, 2004, 06:32 PM
Personal Sales Rating: ( 1)
Drives: 03 SRT-4 400hp+, 350z, 96 corolla.
ON my srt-4, i have real time wideband info. I too use the lm-1. Basicly you take the LM-1 and hook it up to your puter and you program what outputs you want.
I set mine to 1v-10/1 afr and 5v = 20/1. Now you go into channel 1 of the emanage (white wire on harness) and set the parameters the same as above. THis iwll give you real time afr dispaly on the screen.
Offline
Tags
02, 03, 10, 350z, emanage, evo, evolution, ix, location, o2, oxygen, sensor, srt4, viii, wideband  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
