i refer to my experience with my 3000GT :
you have in a MAF 3 sensors : air temperature, barometric pressure sensor and mass air flow sensor.
if you go to speed density or MAP sensor :
-you will need to fix the baro signal to the ECU ! because the mass air pressure will increase or dicrease in fonction of altitude !
so just put a variable resistor to fix this baro signal at 1.00bar ( perhaps with the help of a datalogger )
-then you can play with the IAT sensor ! just let a stock IAT on the engine bay and let the ECU compensate with fuel and/or timing. not that good.
-or buy and put a new sensor like GM part IAT not far from the throttle of your car.
->you will need to fix the IAT signal to ECU with a variable resistor (20°C or 68°F read with the datalogger)
-> use a variable resistor and the new IAT and modify the wiring of the EMU !
then in the parameters settings, chose CH setting + air temperature !
and play with timing and fuels maps dedicated for Intake temp.
this is a picture before and after a wiring modification of my IAT
before, the air temp is read by the ECU and EMU.
after, a fixed resistor is used to fix the air temp to the ECU, and a pull up resistor is used on the EMU wiring to put a new voltage reference.
for some bugs :
just with hardware and some chips dissoldered of the electronic board !
and for me, a bug on my NVCS map that i rewrote in real time and all was ok after this !
a standalone is a best way for sure, but for someone who want to make tuning corrections by itself, a EMu is a good product !
and for piggybacks, just take a look to the Map-ecu2 ! really amazing for the price !
fred
