Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Greddy E-Manage
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 7, 2005, 02:36 PM   #1
Personal Sales Rating: (0)
Insidious Evo's Avatar
Drives: Tarmac Black Evo VIII
Question E-Manage Ultimate
I did a search but found nothing. Does anyone have any experience with this new unit? I read about this and it looked like it was able to eliminate the Mass Air flow sensor and go speed density. I have seen all those U-tec boys messing around with that maftpro unit, but I think Greddy might know alittle more about tunning. So I called Greddy and the said that it was true, but only on certain cars. They said they were currently working on making it work in the Evo!
Here is what Greddy's website had to say about it.
"The GReddy e-manage Ultimate was engineered to preserve the best features of the original e-manage (an economical price, the use of existing sensors, the ability to easily alter stock settings, & the vast compatibility for most Japanese performance vehicles), while advancing new innovations in piggyback engine control management. Although the external physical dimensions are the same, the Black-Chrome Ultimate has an increased number of input and output ports along with new built-in adapters, to add a number of new options.
In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. Included is a PC-based Ultimate Support Tool software CD, with an easy-to-use Parameter Set-up, tab menu format and speedy USB communication. Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate's improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates.
Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. "
It looks like a cheap and realiable solution to go MAP.
- Erik
__________________
Insidious - in·sid·i·ous adj. Working or spreading harm in a subtle or stealthy manner
With function, follows style. Example: Evo
www.BilletDesign.com <--the best tunning shop in Florida, not only for Evo's
Offline
Old Nov 10, 2005, 06:11 AM   #2
Personal Sales Rating: (31)
phenem's Avatar
Drives: '03 Silver 2.3 EVO8, '07 Black Outlander XLS!
Send a message via AIM to phenem
This would be great to know because I am about a week away from purchasing my Ultimate. There are a lot of benefits that it has over other p-n-p EM.
This would be great if everything worked out on the EVO. I am ordering everything the main harness to control the injectors down to the MAP sensor to get rid of my MAF sensor.
I will keep this thread updated with information as I find out anything.
__________________
2.3L stroker, GSC S1 cams, GSC valve springs w/ retainers, CBRD BBK Full, PPI ported exhaust manifold, BR Race FMIC, BR Short route piping, Mini Battery, Dynatek CDI, stock ECU running v7 SD, Wilson V0 intake manifold, PPI 65mm TB, BC street coilovers, Perrin rear sway bar
Offline
Old Nov 19, 2005, 08:44 PM   #3
Personal Sales Rating: (14)
Randy's Avatar
Drives: EVO 8 GSR
Send a message via AIM to Randy Send a message via MSN to Randy
I have seen it at work in a TT 350z and it is frieking amazing, flowmeter deleted, tuning using the Greddy Pressure sensor simply amazing.
Wondering how I can upgrade my blue to an ultimate. Will keep reading.
__________________
__________________
Tuner: Chris Black
443whp Pump Gas
387wtq Pump Gas
22 pounds of boost
2.3L Stroker Kit
AMS 3076R Kit
2006 NASA TTB Champion
2007 NASA TTS Champion
Colo Performance
Predator Performance
Daily Driver Machine
Golf Addict
Offline
Old Nov 19, 2005, 09:22 PM   #4
phenem's Avatar
I talked to Greddy and the guy didn't no jack! He said they have not got it working 100% on an USDM EVO yet. They have the right injector "harness" and coil pack "harness" but they don't know which of the two types of harness's to use. Whatever that means.
He also said that they are in contact with Japan to find out how they got it to work on their EVO. And that it should be figured out in the next couple months.
If this is figured out I am definetly getting my hands on it. It is as close to a standalone EMS that you can get without sacrificing standard emissions and daily drivability.
To me the "ultimate" (hence the sarcasim) ticket to having a street/strip car.
__________________
Offline
Old Nov 23, 2005, 11:33 AM   #5
bump for more info
__________________
Offline
Old Nov 30, 2005, 05:48 PM   #6
Personal Sales Rating: (5)
BoostAddicted's Avatar
Drives: 2003 Apex Evo VIII
Quote:
Originally Posted by Insidious Evo
bump for more info
anyone have any more info yet?
__________________
"Aerodynamics is for people who don't know how to build engines." - Enzo Ferrari
Offline
Old Jan 4, 2006, 04:07 PM   #7
i have a unit for sale including ultimate harness $650. pm me if interested...
Offline
Old Jan 4, 2006, 10:12 PM   #8
Quote:
are you able to delete the maf?
__________________
Offline
Old Jan 6, 2006, 11:38 AM   #9
Drives: 95 Colt / 4G63 Swap
Send a message via ICQ to HPF Michael Send a message via AIM to HPF Michael
You can't delete the MAF. Here is the description I have on my website.
We sell these for $544.00, If you have any questions feel free to contact me (PM or EMAIL).
Thanks,
Michael
Quote:
Finally a product to truly replace the HKS VPC for aftermarket upgraded Vehicles! Since the demise of the VPC from HKS, there has been a huge void to fill to meet the demands of modified car owners looking to a simpler approach to adding big injectors and turbo(s). Many simply do not want to change the factory ECU and move to a standalone. This is a solid solution for those from a world leader in electronics for imports, GReddy.
Greddy Performance Products introduces their newest piggyback engine management system, the e-Manage Ultimate! The Greddy e-Manage Ultimate does what no other piggyback ECU can. Engineered to preserve the best features of the original e-Manage (economical price, no need for tuning from scratch, & compatible for most Japanese performance vehicles).
Some of the new features include:
The ability to both Add and Subtract on fuel and ignition maps A toggle switch to shift between two sets of tuning maps (i.e. Street program or Race program) Air/Fuel Target Map for self-tuning to speeding up initial tuning time Increased number of input and output ports and numberous built in adapters Various Correction Maps (for Acceleration, Speed, Temperature, Ignition, & A/T Trans) Fouled Spark-Plug Cleaning Feature Auxiliary Output Maps A new extensive multi-channel datalogging system with map tracing for easy tuning Includes the software Support Tool CD Use of a speedy standard USB cable for tuning, monitoring, and datalogging Ideal for optimizing and fine-tuning for performance products like exhaust, air intake, intercoolers, boost controllers and turbo upgrades, the e-Manage Ultimate and do it better than any other system on the market today.
Offline
Old Jan 7, 2006, 06:21 AM   #10
Personal Sales Rating: (2)
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
Thanks,
Michael
hi.. yes you can.. but you need the greddy map sensor and you need to manually map each point into the map loadpoints
ie you gotta tell the EMU what equivalent maf is at that particular map point.. not easy but can be done
on top of that you need 2 adaptors in order for the direct injector control to work and ignition control..
theres still some minor issues but it seems to be working ok now
Offline
Old Jan 7, 2006, 12:56 PM   #11
Is greddy going to come out with a base map for evos?
__________________
Offline
Old Jan 7, 2006, 06:04 PM   #12
gunzo's Avatar
There's no base maps for any cars ..
Emanage is an interceptor .. so if 0 values are inside .. it runs the stock ECU values ..
Offline
Old Feb 5, 2006, 01:44 AM   #13
Personal Sales Rating: (4)
feldguy's Avatar
Drives: 2003 Apex Silver Evo
Send a message via AIM to feldguy
Any updates on speed density conversions for the Ultimate E-Manage?
__________________
For good luck, Chuck Norris breaks someone's leg before he goes on stage.
Offline
Old Feb 5, 2006, 10:22 AM   #14
phenem's Avatar
I am very interested in switching over to this piggyback and would like to see if anyone has information they would like to share with their experiences with it. Anyone??
~Zach
__________________
Offline
Old Mar 10, 2006, 11:04 AM   #15
Personal Sales Rating: (36)
spoolint78's Avatar
Drives: supra turbo
Haven't had luck with it for the supra community as well.
No one has been able to move the rev limiter yet.
Still loads of bugs to figure out
__________________
89 supra turbo
15.3@94mph
6.8psi, intake slipping clutch
1994 6spd mkiv supra
t66dbb
meth
http://img206.exs.cx/img206/6844/im0010994ut.jpg
Offline
Tags
3000gt, blue, cel, conversion, convert, density, emanage, forum, greddy, maf, map, sale, speed, supra, tuning, ultimate
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
