Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Greddy E-Manage
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 14, 2004, 11:47 AM   #1
Personal Sales Rating: (0)
Drives: Evo VIII
Emanage + Profec E-01 No Boost
Having a big problem with this engine management setup and looking for help anywhere. I recently did a turbo upgrade to the Garrett GT30R, Tial 38mm external wastegate and am running the following other mods:
APS intake
Greddy 720cc injectors
Walbro fuel pump
B & B turbo-back
HKS SSQV
That should be all the mods that really matter. Actually, the turbo kit was from RNR Racing (horrible fitment and many, many parts missing, but a nice look...especially the equal-length tubular header). I got everything installed and was running about 17lbs (to be safe) at 55% gain on the Profec. I took it up to DynoComp (here in Scottsdale AZ) to get it tuned, and they couldn't sync up to the emanage with their laptops. They managed to get the firmware upgraded though, and then all of the previous settings were erased. I drove it home (it drove like sh@@ btw) and it wasn't holding more than 4lbs of boost.
So, I sent the Emanage in to Greddy, who got it working and sent it back. I hooked it back up and went back to DynoComp and we got all synced up with the current firmware (1.39) and everything, but the car will still not hold any boost. No matter what they changed for settings in the Emanage or Profec, and no matter how they switched around the vacuum lines on my hardware (wastegate, solenoid, BOV and turbine), they COULD NOT get it to produce any decent amount of boost. It'll spool up, but only hit 16lbs at redline and it very, very gradually gets up there. This is how it acts no matter what changes you make to software or hardware now.
What does anyone think? I, nor anyone else, can figure this problem out so far. I believe it to be software related, because it was holding boost before. Any help is greatly appreciated.
Offline
Old Oct 15, 2004, 09:48 AM   #2
Drives: Evo VIII
Actually, meant that set was at 55%, not gain. Going to try resetting the Profec and emanage and running new vacuum lines over the weekend. I'll post what results I get, if anyone's even interested.
Offline
Old Apr 9, 2005, 10:23 PM   #3
Personal Sales Rating: (2)
rraulston's Avatar
ime having the same problem... What did you find???
__________________
Tarmac Black, Stainless step panels, Mitsu shift Knob, Sparco pedals, Halman MBC, Walbro 255, ARP head studs, Evo-9 turbo, PWR radiator, stock injectors, ACT XT-SS clutch, Defi Gauges, Azenis rt-615 x 255 tires, Buschur mini battery kit, Buschur cat back, Buschur upper intercooler piping, K&N Filtration, Unorthadox pullies, HKS 272/272, HKS turbo timer.
Offline
Old Apr 10, 2005, 08:59 PM   #4
Drives: Evo VIII
Found that the new downpipe had shifted and moved after turbo installation and burned a small hole in the intercooler piping. Everything's been fine and dandy since I fixed that issue. The car made over 400 whp on a DynoDynamics dyno (very low reading dyno) with C16 and 25lbs. I run it at 17lbs with 91 octane daily and she makes about 290 whp there. Hope you can find the problem...mine had nothing to do with the Profec/E-manage setup.
Offline
Old Apr 10, 2005, 09:40 PM   #5
rraulston's Avatar
Well, i found my problem. I have to run 0 gain. Manual says the higher the faster the spool. I lowered it and it works fine. Wow, i run 28 psi with 100 and NO knock......
__________________
Offline
Old Apr 12, 2005, 05:30 PM   #6
Personal Sales Rating: (1)
teamdomokun's Avatar
Drives: 2000 HOnda civic
Send a message via AIM to teamdomokun
dude this is a ****ty setup.... while AMS was tuning my car recently my profec e01 completely failed(apparently little black lines shot across the screen until it wouldnt work at all) and the emanage is just not a good tool for tuning. It works great for fuel tuning, but horrible timing control(plus it fries the ignition coils). I upgraded to the AEM EMS which is a much better unit. Especially if you are running alot of mods like upgraded turbo.
__________________
2007 GSX-R 600
2000 Honda Civic
Offline
Old Apr 12, 2005, 10:46 PM   #7
rraulston's Avatar
I only have the E-01 for boost controll. I use the UTEC for managment. No emanage here. I am getting really bad MAF fluctuations and am thinking AEM. I think that would clear up all my issues.. Comments?? ray
__________________
Offline
Old Apr 13, 2005, 02:32 PM   #8
Quote:
I think thats your best option for an upgraded turbo as long as you have a knowlesgable tuner tuning it.
__________________
2007 GSX-R 600
2000 Honda Civic
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
