The Tactrix cable has an OBDII connector (and, for some Tactrix cables, a reflash connector) on one end, and a USB connector on the other end that just connects to a regular USB port on your PC.
You do not need a USB-serial adapter to get EvoScan to work.
USB-serial adapter is useful if you have an AFR unit that provides a serial data stream output, so you can log AFR using the software that came with the AFR unit, or to import your AFR data into EvoScan for logging alongside the other data that's logged via the OBDII port.
