Oct 21, 2009, 02:12 PM
Personal Sales Rating: ( 0)
Drives: EVO VIII 2004
evo viii 260 cyprus
Hi guys new here.some help please? i have an evo viii 260 how can get it up to 400bhp?
Offline
Oct 21, 2009, 02:16 PM
Personal Sales Rating: ( 6)
Drives: '03 RRM Turbo Lancer gone; 2004 EVO 8 RS!
turbo, cams, intake, exhaust, tune, ported manifold, intercooler, intercooler piping...
and doing some research....read, read, read
__________________
FP Green (ported/coated), O2 Pipe (coated), Stock Manifold (ported/coated),HKS 272 cams,HKS RS Intake with Amsoil Filter, TurboXS FMIC, Custom UICP, APS Twin Vent BOV,AMS LICP,3in TBE (no cat),ACT HD clutch, Prolite flywheel,Shepp Stage 2 T-case, Odessey PC680 mini batt, Evolution Dynamics Mini Battery Mount, KW Variant 3, Greddy EBC, TephraMOD ECU, Aquamist HFS-5 @100% meth! @ 30psi...
BUILT & TUNED BY KEVIND @ Evolution Dynamics!
Online
Oct 21, 2009, 02:27 PM
thanks made.what about 1st stage upgrade?
Offline
Oct 21, 2009, 02:36 PM
Drives: 04 Lancer Evolution; 05 Chevy Silverado; O3 XR250R
My first stage was fuel pump; intake; cams; cam gears; valve springs; retainers; 750 cc injectors; fuel rail; O2 housing; downpipe; high flow cat; cat back exhaust; SS clutch line; clutch; metal head gasket; arp headstuds; mbc; and tune. that brought it up to 300whp on 91 @ 24PSI on my VIII.
__________________
"A fit young racing driver in a supercar and he can not pull away from a fat man in a four door saloon."
Jeremy Charles Robert Clarkson
Offline
Oct 21, 2009, 04:49 PM
1st of all you dont need headgasket, ARP head studs, cam gear, valve springs, retainers, fuel rail to make 400bhp.
i making 400hp at the wheels and have none of that.
but walbro 255 fuel pump, and clutch/flywheel are needed as well.
check this place out.
www.buschurracing.com/
or...
http://www.amsperformance.com/
or what ever other shop you want.
look at the parts i have and go from there....but for turbo i would go with the FP Red.
__________________
Online
Oct 22, 2009, 04:51 AM
thanks man thats what i thought .whats the best cams for evo 260?
Offline
Oct 22, 2009, 04:55 AM
thanks that is what i thought.which are the best cams for evo 260?
Offline
Oct 22, 2009, 04:58 AM
Offline
Oct 22, 2009, 08:33 AM
Kelford 272s...dude just do some reading..
__________________
Online
Oct 22, 2009, 08:43 AM
Personal Sales Rating: ( 2)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
the search button is your friend... turbo upgrade, fuel pump, cams, mbc, tune and clutch, exhaust, o2 dump, intake and a ported exhaust manifold should do it...
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Oct 27, 2009, 05:07 PM
2003 Mitsubishi Lancer Evolution
Drives: 03 RR/TB Evo 8 (Skunk2 Powered), Afghan Gator AWD
Head studs aren't recommended until you reach around 500WHP. That's the widely held limit that the stock head studs can withstand. You can always put them in but if you aren't making big gains in the engine and everywhere else on the car then there is no point in dropping them in.
Also remember that when you start upgrading engine components you need to also upgrade the rest of the car: suspension, wheels, tires, stiffening components. You could have an 800WHP vehicle but if you're running stock everywhere else you're eventually going to run into problems.
If you go wild on an engine component upgrade you also want to get your car tuned to handle all the new changes that you have introduced. You will not achieve significant power gains until everything is tuned/balanced for what you have dropped in. You could also cause damage to the engine if you run the car long enough without getting a tune performed after a major change in the engine itself.
The Evo is built rather solid, but also remember that it's built for the components that come in it from the factory. Any changes in one part of the vehicle need to be compensated for on other parts of the vehicle or you will eventually be left with a poor performance vehicle that you have sunk all this money into that does not perform as well as you had hoped.
I understand you are new so you want to know as much as possible as soon as possible but everybody has a different idea as to what should be done to the car and in what order. Do some reading on the forums and some personal research to find out what you will need to do to reach your target and understand that for a 400WHP vehicle you will be spending a lot of money to get where you want as well as a lot of time in a garage tuning to achieve those numbers. This is your vehicle so you need to understand it before you will be able to understand the advice and insight that is available to you.
Welcome to EvoM...
__________________
Exhaust | Boost Dealie | Turbo Thingy | Dark Interior | Distracting Gauges | Wheels | Cusco bits | Pretty Colors
Currently in storage collecting dust and pure, white hot rage for the streets...
Reason: spelling errors
Offline
Tags
260, cams, cy, cyprus, ecu, evo, filter, fuel, gsr, hks, problems, pump, rs, tune, upgrade, walbro  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
