Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > General Engine Management / Tuning Forum
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 19, 2009, 07:46 PM   #1
Personal Sales Rating: (0)
evodan_socal's Avatar
Drives: 03 EVO VIII
Question Removing RRE dual map switch????
So, I had my 03 EVO tuned by RRE in Dec 08. It ran great and made some pretty good numbers on the dyno. Around Apr 09 the car started running really rich, blowing black smoke out of the exhaust, and had uncontrollable boost spikes. I tried contacting RRE, but no love.
Frustrated, I tried changing out obvious parts starting with the dual stage MBC. That stopped the boost spikes, but still running rich and and blowing smoke. Then I changed out my Greddy RS BOV with an AP BOV, that helped a little bit, but still rich and smoking at WOT like Cheech Marin. Tried contacting RRE again to get my ECU reloaded, but I got no reply.
Finally, I decided to send out my ECU to Dynoflash. When it came back, it wasn't running rich, but I needed to change a few things. The boost solenoid needed to be bypassed and the stock injectors had to go back in. I am still getting a CEL though. I would guess it is because the dual map switch is still wired into my ECU.
My question is ... does anyone know how to remove the switch and wiring?
Thanks.
Offline
Old Oct 20, 2009, 05:33 PM   #2
Personal Sales Rating: (1)
Drives: 04 RS
Try posting here;
http://www.socalevo.net/index.php?op...=37&board=56.0
Mike checks regularly.
Offline
Old Oct 20, 2009, 11:23 PM   #3
Drives: 06 GG Evo IX MR
Quote:
^^^ Not so sure.
Anyway, I think it's likely the dual map switch RRE installed is just a 'Jack of Trades' alt-map switch. Install instructions for 'Jack of Trades' alt-map wiring harness is here: http://dsm-ezine.com/Install_Instructions.zip Just do the reverse of the install instructions to remove the relevant wiring.
Offline
Old Oct 21, 2009, 12:19 PM   #4
Personal Sales Rating: (3)
Jim in Tucson's Avatar
Drives: '03 EVO VIII, '04 Prius
I'm really confused here. I had my dual map set up done at RRE as well. The EVO VIII does not require any kind of switch to be installed, as does the EVO IX. The EVO VIII uses the ICS switch in the console.
In any case, if you do have a map switch, and if you are now flashed back to a basic straight up ROM w/o dual maps, the switch should do nothing. Simply cut the wires, remove the switch, and tape off the ends.
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
Old Oct 22, 2009, 06:20 AM   #5
Quote:
True, the Evo VIII does not require a switch to be installed for alt-map switching, however it is one of the methods supported. In fact there are three separate methods supported:
- ICS switch
- TPS
- Alt-map switch & wiring harness
Offline
Old Oct 23, 2009, 11:00 PM   #6
Personal Sales Rating: (61)
evovin's Avatar
Drives: Evo 8
http://driven2modify.com/showthread.php?t=21863
__________________
10.90@129mph(sunnoco 116)
best trap 135mph
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
http://www.turbotrix.com/wordpress/
SparkTech Ignitions
http://www.sparktechignitions.net/
Offline
Old Oct 24, 2009, 11:38 PM   #7
Drives: 03 EVO VIII
thanks guys.
Offline
Tags
flash, map, rich, rre, tune
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
