Oct 18, 2009, 04:46 PM
Personal Sales Rating: ( 4)
Drives: 2003 Evolution, 1998 Trans Am
Cant read Write ECU with evoscan???
So i got the program to log my evo but i cannot read or write to the rom, it says error usb cable disconnected or in use
Offline
Oct 18, 2009, 04:49 PM
Personal Sales Rating: ( 50)
Drives: '06 RR IX RS / '99 Maroon GSX
Is Evoscan running while you try to write to ecu via Ecuflash? if so, disable Evoscan and then write.
__________________
◄ ◄ K U N i i i Z Z Z E E E ► ►
"OCD isn't a disease..it's a lifestyle" -revvin9k
-||'06 RR E9 RS||-
ROBISPEC/// "...live a little!"
...powered by: żMagic?
Offline
Oct 18, 2009, 05:14 PM
i am trying to read the ecu with evoscan i dont have ecuflash
Offline
Oct 18, 2009, 05:48 PM
Personal Sales Rating: ( 2)
Drives: 2003 blue EVO
evoscan is a data logger. you can only read the ECU when you have the live graphing turned on.
ECUFlash is the tool you need to modify the rom.
another possibility is that your ECU is "locked" with a scrabbled ECU ID, and you will have to locate the unlocker tool to clear this up before being able to read the ecu properly
__________________
autocross nut SFR SCCA #52 SM
Offline
Oct 19, 2009, 10:03 AM
how would i just turn the live graphing off so i can read write with evo scan?
Offline
Oct 19, 2009, 11:02 AM
so i downloaded ecuflash and i tried to read my ecu and it came back with no response to any known code and closed the interface? i know we can get into the ecu my tuner does all the time using the same software what am i doing wrong?
Offline
Oct 19, 2009, 06:27 PM
Personal Sales Rating: ( 0)
Drives: the short bus
you need to run the ecu unlocker first in the back ground then open ecuflash and read from ur ecu
__________________
GG EVOLUTION IX MR
AMS TBE Exhaust, Walboro 255lph, Hallman MBC RX Pro, Perrin air filter
340whp 340 ft-lbs
Offline
Oct 19, 2009, 06:35 PM
Drives: 03 EVO VIII
I'm a noob to data logging and tuning. Which cable do you have? I have the same problem bc I bought the tactrix opensource 1.3r cable. It says for reading and writing but it doesn't. It also has the extra wire with connector to flash ecu.
Also, my evoscan has a button that says write to ecu. Why? If it doesn't have the capability then why is it there?
__________________
Work Hard,
Play Hard,
Or Go Home!
Perrin DP
Hallman MBC
Tsudo CBE
Cusco Heat Shield
Forge BOV Recirculate
K&N Intake
Weapons R Grounding Kit
RO_JO Wheels
Defi Boost Gauge
Offline
Oct 19, 2009, 08:15 PM
i have the tactrix 2.0 how do you run the ecu unlocker?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
