Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > General Engine Management / Tuning Forum
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 22, 2009, 08:46 AM   #1
Personal Sales Rating: (1)
Nelissen's Avatar
Drives: evo VIII
Obdii
Wich parameters will be shown by the OBDII on a Evo VIII ??
Eric.
__________________
Dutch Evo VIII Driver
Milltek 3",Apexi power intake, RH J 8 19", Rexspeed, EXE TC Suspension.ETS licp,ECU_Art ECU flash.
Offline
Old Sep 22, 2009, 09:49 AM   #2
Drives: 04 RS
It depends on the logger and software. With my cheap palm and free software I only get the basics;
rpm, throttle, timing, air temp, O2's, fuel trims, etc.
http://students.db.erau.edu/~szabafab/stein/
With evoscan ($25 usd) and a laptop I can log all the basics plus things like solinoid duties, knock, injector pulse width, and numerous other things.
http://www.limitless.co.nz/
All of these work through the OBD-II port.
Offline
Old Sep 22, 2009, 12:34 PM   #3
Nelissen's Avatar
Drives: evo VIII
What about the boost, can you read that to ?? i will use dashcommand on my carpc embedded in Centrafuse.
Eric.
__________________
Offline
Old Sep 22, 2009, 01:52 PM   #4
Drives: 04 RS
We can't log boost through the OBD-II port without changing the MAP sensor and adding to your ROM;
log boost with JDM MAP sensor (updated instructions)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
